nvm. errors were caused by overrun protection ![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
test fw dont work with tip/handle disconnected
What errors are you talking about?
Is that a proper error reporting?
"Don't work"? No problem, I'll fix the "no work" problem
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Currently the big NO IRON text won't be displayed because there's no russian symbols, but all others, yes.
Else than that, it should be working normally.
Some tweaks had to be made of course, like adding 'ÅÄÖ' etc.
Made a mini setup with a KSGER 2.1 + 3.1 controllers. Added audio jacks since I expect MP3 support soon ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Jokes aside, there a lot of blind people using the firmware, or at least they don't know how to read the instructions, asking the same things again and again, so the MP3 could be for voice guidance
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
If you modified the existing bdf fonts to add these characters, then why don't commit the changes?
For a few characters it's ok, but as it needs to be done by hand, it's extremely time consuming if you have to add a lot.
But that's what needs to be done here.
Currently I'm using a different font for russian, it would be much better to modify the current fonts instead.
But ain't just normal letters with accent marks...
Wickated, seems you'll have some work to do.
Time to start compiling and trying the translations,. it's very easy, It just takes a lot of trial to fit everything nicely
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Will post some guidelines later.
