Not happening here.
After factory reset, I created "2","3","4","5"... Deleting BC3(1st tip), deleted exactly that one.
Deleting any other tip also worked as it should.
Please describe the exact procedure to reproduce the issue.
Ensure you're using the latest, made few hours ago.
Since I've been doing multiple builds daily, it's a little confusing.
Update after writing this message: I can't see that boost feature. Clicking github link in your signature, I see last commit 7716267 6 hours ago. Then, in BOARDS/Quicko/STM32F103C8, I see a09f40c 8 hours ago, which is the one I'm using. So I does look like I'm not getting the last update. FWIW, I'm including the report for a09f40c.
(somewhere in the past)
Well, the exact procedure is almost as I said... using last commit a09f40c. It's true that after calibrating, I have been able to delete BC3 as expected. But, to be sure, I flashed it again. What I see now is, after creating a new tip, going to BC3 I got into the last tip created -still uncalibrated. So, created DFLT, just named, saved, selected BC3 (still in Edit Tips menu), clic... and got into DFLT settings. Cancel. Created BC2, just named, saved, select BC3, clic... got into BC2. Create D16, just name it, save, select BC3, gets you into D16.
Selecting any created tip in the Edit tip menu, gets me into the last created tip settings. BC3, DFLT, BC2... no matter, selecting any of these I got now into D16 settings.
After that, selected BC3, clic, got into D16 settings, delete. D16 gets deleted. Now selected BC3 again. Clic. This time I got into default settings with a blank name. Cancel. Same with DFLT and BC2, I get into default settings with blank name.
After that, in main screen, clic+rotate right, selected DFLT tip. Then, in Edit tips menu, again I always get into default setting with blank name, no matter which one i select.
So, again in main screen, click+rotate right, select BC2 tip. Calibration->Adjust. Save.. Edit tips. Still default settings with blank name.
Calibration -> Start. Back. Exit. Edit tips. Same again. Any tip I enter into, has default settings and a blank name. Included the calibrated one. But, If I get into any of these and delete it, is that tip the one that gets deleted.
Well, last time somehow I was able to get it working. Not this time.
