It's there because, at least at sight, it has the same conections as the 3.1.
Schematics:
v3.1v2.0As I replied in YouTube, recently there was a bug that broke all these boards. Did you try the latest files?
When you say it doesn't work properly, please explain better. I can't do anything otherwise
So first, flash the latest 3.x version. If it still doesn't work, explain what's wrong!
Ksgers needs some tuning with the PID because I don't have any myself.
The PID values are set from my Quicko tests and other people's feedback!
It needs temperature calibration by default, because I barely have any feedback from users, so I had to put safe values which are far behind the real to avoid people burning their tips.
If you don't have thermometer, try setting this values in the first system tip.
After that, new tips will use that data by default.
Cal 250 - 1459
Cal 350 - 2215
Cal 450 - 3213
But if you have it, then run a proper calibration like shown in the vídeo.
