Can't see for sure in the photo, but looks like U2 middle pin is not soldered.
When you use smart active, what's the lowest load value you can get?
The lowest I can setup in my ksgers is 6, the other ksger needs 8 (I use c245 in both).
It's much better using smart load when soldering, specially if it's a larger copper mass.
I'm really happy using this FW, thanks @davidalfa!
