Hi everyone,
I had a go at flashing this onto my newly purchased Quecoo T12-958, which was previously working. The only hardware modification I have made is to move the earth wire to the correct place as the tip was not earthed.
I followed the instructions and upon flashing, the controller went dead and never came back to life. No response to the encoder, no display, no buzzer. I can't find the original firmware .bin, and flashing the T12-955 .bin just results in a constant buzzer with no display, and flashing the Quicko T12 F103 .bin also results in a completely dead station, so the station is currently unusable.
It's got a genuine STM32F103 with 128kb memory. It also has an OLED display. I installed CubeIDE 1.12.1 and built the firmware using option 8 ('Quicko 103 OLED'), which completes successfully. I then flash SSD1306.bin using the 'Program verify' mode of the ST-LINK V2, which completes successfully (see attached).
I can't see what is going wrong here. Is it possible this is a new hardware revision that CFW does not support? I've attached a picture of my control board. If anyone has the original T12-958 firmware dump too I'd appreciate if you can share it!
The only thing that sticks out to me is that the built firmware file is 109kb, not 128kb like the original .bin files.
Thank you in advance.
