Hello guys, maybe it's a bit wrong thread, but I am looking for CFW compatible T12 soldering station + hot air gun and need your advice what to purchase. I know that 858D is most recommended hot air gun, but would like to have a compact one, so after searching through aliexpress for few days got these options:
Handskit:
Hot air -
https://www.aliexpress.com/item/1005002965789645.html - (pros: cheapest one, separate gun stand; cons: not sure about overall quality, has calibration issues, requires replacement of some resistors and adding case grounding)
T12 -
https://www.aliexpress.com/item/1005003155390894.html - (pros: cheapest one, has stand and ok handle I guess; cons: also not sure about overall quality, and about MCU used in latest versions (vendor could cheap out and use STC boards, those are used in their same stations but with external PSU), OLED with not standard pinout and low brightness)
* I don't mind some HW rework if overall their HW design in terms of schematic and elements placement is ok.
Quecoo:
Hot air -
https://www.aliexpress.com/item/1005004884759470.html - (could not find any reviews)
T12-955 -
https://www.aliexpress.com/item/1005001608493682.html - (pros: price is good, especially with 5 tips (not sure about their quality), CFW compatible; cons: slow I2C display)
T12-958 -
https://www.aliexpress.com/item/1005002724765690.html - (pros: SPI display and some HW updates as told by vendor (?), CFW compatible; cons: price)
T12-958 V3.1S -
https://www.aliexpress.com/item/1005003302164155.html - (what is the difference vs T12-958?)
* both have sturdy aluminium handle, but I'm not sure about how fast it will get uncomfortably warm during long soldering sessions.
** also are these T12 both have best HW implementation in terms of grounding or only 958?
KSGER:
Hot air -
https://www.aliexpress.com/item/32844169715.html - (pros: non hazardous connection of heat gun, saw review on youtube, looks like it's all good, but it wasn't indeep review, so don't know does it need any HW changes or not; cons: price)
V2.1S -
https://www.aliexpress.com/item/32871815985.html - (pros: same as Quecco's; cons: price)
V3.1S -
https://www.aliexpress.com/item/4000453770565.html (pros: same as Quecco's; cons: even higher price, especially with decent handle)
Some paired devices:
858DS -
https://www.aliexpress.com/item/1005003801198284.html - (don't know what's inside, there are any reviews)
KSGER 1 -
https://www.aliexpress.com/item/33040946949.htmlKSGER 2 -
https://www.aliexpress.com/item/32843211322.html* as I understand none of these are supporting CFW?
Also was looking at OSS T12-X, T12-959, KSGER V2.3 - they are good overall, but have dimm display or bad color scheme (red-white or red-blue, like wtf) and I need CFW for ability to store calibration of different tips and none of these have this option.
P.S. What do you think about this handle
https://www.aliexpress.com/item/1005004143441464.html? I like it's design and flexible strain relief part, but looks like overall it's like 9501 and other plastic handles, those may become soft close to the tip during long time soldering at high temp or does it have better plastic, maybe someone using it?
P.S.S. I've seen Handskit T12 with silver front panel, not sure what is the difference between them, but possibly there is STC controller in the one with black panel, can anyone confirm?
