Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 880162 times)
0 Members and 17 Guests are viewing this topic.
Online moffet
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #2575 on: January 05, 2022, 10:28:22 am »
Can anyone provide instructions on how to convert KSGER 2.1 station to support T245 handle?
I have attached a photo of my board.
Thank you.
Offline wickated
  • Country: ru
« Reply #2576 on: January 05, 2022, 11:09:13 am »
cut r11 trace
Online moffet
« Reply #2577 on: January 06, 2022, 10:57:34 am »
cut r11 trace
Ok. Is this correct? Where should I connect TC+, to NTC?
Offline wickated
  • Country: ru
« Reply #2578 on: January 06, 2022, 12:40:49 pm »
watch the trace nearby r11 and ull see special pin dedicated to jbc tc+ (lowest in 6 rake)
The following users thanked this post: moffet
Offline Tugo
  • Country: si
« Reply #2579 on: January 06, 2022, 12:44:34 pm »
T12 has heater and thermocouple in serial.
That trace that you need to cut is to split power (+24V) and input of U3 amplifier (this is to know what is the temperature on the thermocouple).
I hope I explained it clearly. If not, just ask.
So you need to connect TC+ to JBC (also where is says: "this trace wrong on some boards"). So your thermocouple will go to R12D (pin 5).
Everything understandable?
EDIT: I guess I was a little bit too slow  :-DD
Offline DavidAlfa
« Reply #2580 on: January 06, 2022, 02:54:50 pm »
Online moffet
« Reply #2581 on: January 06, 2022, 04:14:53 pm »
Understood.
I guess I have to also replace original 75W power supply with something bigger, like this one:
https://allegro.pl/oferta/zasilacz-impulsowy-24v-240w-10a-cnc-led-reprap-11019179682
Offline Tugo
  • Country: si
« Reply #2582 on: January 06, 2022, 08:02:59 pm »
I don't think you need it. At least you don't need it from the start. You can use your current PSU. You just have to go into settings and limit power.
David, am I wrong about this?
Offline DavidAlfa
« Reply #2583 on: January 06, 2022, 09:07:35 pm »
Meh, the cheap 75W rarely handles that, usually it resets or greatly reduces the voltage.
Try it, if it goes bad then get a better PSU.
Offline DavidAlfa
« Reply #2584 on: January 24, 2022, 02:33:01 pm »
There's a new model, the T12-959, with 2.6" LCD.
It seems to use stm32 but I didn't find any board pictures.
https://a.aliexpress.com/_msv7R9K
Offline mastershake
« Reply #2585 on: January 24, 2022, 05:24:22 pm »
one of the ones i received that looks like that one has an stc not stm on the board
Offline ygi
« Reply #2586 on: January 24, 2022, 07:16:21 pm »
It's actually written on the product page:
  • Using STC15W408A5 microcontroller,
  • Use sGM855xN high precision op amp,
Offline DavidAlfa
« Reply #2587 on: January 24, 2022, 08:55:05 pm »
Ouch, how did I miss that in the description?
These say stm32, but they also say it's OLED. I doubt any is actually true.
https://es.aliexpress.com/item/1005003502334733.html
https://es.aliexpress.com/item/1005003713432532.html
https://es.aliexpress.com/item/1005003526410748.html
STC (Now?) has english datasheet and website:
https://www.stcmicro.com/stc/stc15w408as.html
Seems a basic 8051-based MCU, only 8K flash and 512B RAM.
But has enhanced execution times, much faster than traditional 8051.
Up to 35MHz, that gives more than enough processing power, but the memory is definitely very limited.
« Last Edit: January 24, 2022, 09:10:36 pm by DavidAlfa »
Offline ygi
« Reply #2588 on: January 24, 2022, 09:39:06 pm »
Yeah, it seems very unlikely that someone would make a clone on a completely different microcontroller and bother recreating the same firmware. Most certainly they are all using STC.
Now, that chip may be enough for its purpose but that's a definite rock bottom downgrade for anyone wanting to hack it.
Offline DavidAlfa
« Reply #2589 on: January 24, 2022, 10:09:36 pm »
Hmm and the Quicko T12-958 seems to be a KSGERv3-compatible.
Offline illiac4
  • Country: si
« Reply #2590 on: January 25, 2022, 04:37:42 am »
If anyone needs T12 tips, here is the pack of it for less than 20€
https://www.banggood.com/groupshopping-item-2293069_1191594.html?cur_warehouse=CN
Offline mastershake
« Reply #2591 on: January 25, 2022, 05:04:24 am »
vulkan over at dangerous prototypes put the unisolder into the ksger style case as a lite version now looks like
« Last Edit: January 25, 2022, 05:06:39 am by mastershake »
Offline luqash
« Reply #2592 on: January 26, 2022, 03:45:26 pm »
Can anyone provide instructions on how to convert KSGER 3.1s station to support T245 (C245) JBC handle?
HELP :)
Offline wickated
  • Country: ru
« Reply #2593 on: January 26, 2022, 10:50:00 pm »
cut at x mark. solder at bolb mark
Offline DavidAlfa
« Reply #2594 on: January 27, 2022, 12:23:42 am »
Then follow this connection.
Edit: Also added pcb picture just to annoy Wickated :D
« Last Edit: January 27, 2022, 12:36:55 am by DavidAlfa »
The following users thanked this post: wickated
Offline wickated
  • Country: ru
« Reply #2595 on: January 27, 2022, 08:18:59 am »
noone complaining bout FW ? im still on like september build and feels ok.
Offline DavidAlfa
« Reply #2596 on: January 27, 2022, 12:58:54 pm »
There aren't big changes, just minor gui bugfixes you'll rarely encounter.
The settings structure isn't changed, you could update right away keeping everything.
Just in case, make a backup of the flash...
Offline luqash
« Reply #2597 on: January 27, 2022, 01:28:43 pm »
ma soft suck...
standby time (manual option) minimal is 1 minute....
Offline luqash
« Reply #2598 on: January 27, 2022, 01:32:38 pm »
How I can change soft?
my processor is MindMotion MM32SPIN27PF not stm32...
Offline luqash
« Reply #2599 on: January 27, 2022, 02:52:27 pm »
Stlink cant read processor…
I connect 3.3v gnd swdio swclk and cant read
