Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 839159 times)
zalvis and 8 Guests are viewing this topic.
Offline wickated
  • Country: ru
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #2025 on: September 08, 2021, 11:06:24 pm »
screen full off in slp and runmode is awesome feature  :-+
wrote adc avg (350+450)/2 numba and got just as close to 400 as i wnted. cool. now only two numbas to rape encoder.  :-DD
p.s. nice new "no iron" in russian  8)
got adc offset 10. stand loop adds 30. also as i remember ad8605 is not zerodrift, just very precise and very fast. i guess i should find ad8628 which has almost zero offset.
jbc tips are so precise i can get 1 adc sample unit change with just a breath near the tip.
now i can grow some bacterias in petri with my ksger controller thanks David!
for jbc ad8605 ksger 2.1
was
350 2660
450 3460
now
offset 10
250 1900
400 3050
« Last Edit: September 08, 2021, 11:21:42 pm by wickated »
Online DavidAlfa
« Reply #2026 on: September 08, 2021, 11:49:48 pm »
Your amp drift is ok, 20adc is just 3°C or so.
The problem is like mine, 360.
I also have a lower amp gain, for 450°C it needs ~2300, so the offset has a deeper impact.
I recall screwing something up few months ago after soldering something related to the JBC, the drift became larger, reverting the mods didn't fix it, and it became part of the family.
I don't want to modify my board,, has suffered all kind of torture during the development, there're damaged pads everywhere, specially in the screen and T12 connections, which need to be desoldered to access the back of the PCB(Where the amp is located).
I asked Quicko for the board only, they wanted 20$, which is a bit wtf when I can buy the whole kit for $34...
You didn't report any calibration results! :-/O
« Last Edit: September 08, 2021, 11:55:15 pm by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #2027 on: September 09, 2021, 12:00:18 am »
sorry im just abusing manual cal set :-DMM
and had only quick test without actuall calibration cycle.
test was ok - 250c was ~250c, 400c was ~400c
Offline ricktendoTopic starter
  • Country: hn
« Reply #2028 on: September 09, 2021, 06:16:40 am »
David maybe you or another member could design and make your own PCB better than KSGER & Quicko, selecting and using only the best parts!
Offline wickated
  • Country: ru
« Reply #2029 on: September 09, 2021, 07:07:29 am »
there is already project for combo station with hot air gun channel,, but i obviously think its fw is much less comfortable
Online DavidAlfa
« Reply #2030 on: September 09, 2021, 09:38:32 am »
I already designed a similar controller months ago because I was bored.
It's untested, unfinished (NTC on-board), not in my current plans doing anything else with it. The Proteus files are there.
There're good enough controllers. With little modifications (Op-amp, some capacitors, LDO) some ksgers will perform great.
The following users thanked this post: ricktendo
  • Country: hn
« Reply #2031 on: September 09, 2021, 07:01:25 pm »
I hope somebody takes it or is inspired by it and does a GoFundMe
Offline wickated
  • Country: ru
« Reply #2032 on: September 09, 2021, 07:02:02 pm »
LITTLE
from this way its just like if i bought only stm32 and pcb.
but if make new controller ill say it would be better to make full new project with bigger resolution display(for better graphics) and dual channel (for tweezers support or 2 handles)
« Last Edit: September 10, 2021, 01:50:31 am by wickated »
Online DavidAlfa
« Reply #2033 on: September 09, 2021, 10:10:21 pm »
I need these translations to make the next builds:
.SYSTEM_Oled_Dim = "Dimmer"
.SYSTEM_Oled_Dim_inSleep = " In sleep"
Max. 10 char:
.CAL_ZeroSet = "Zero set"
.CAL_Sampling = "Sampling"
.CAL_Captured = "Captured"
« Last Edit: September 09, 2021, 10:19:03 pm by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #2034 on: September 10, 2021, 01:38:34 am »
.SYSTEM_Oled_Dim = "Затемнение"
.SYSTEM_Oled_Dim_inSleep = " Реж.Экрана"
for current off=screen off, on=screen on and dims
.CAL_ZeroSet = "ХолСмещОУ"
.CAL_Sampling = "Замер.."
.CAL_Captured = "Записано"
also there is mistake in big "NO IRON" in russian translation, 1 char missing  :'( should be "ОТКЛЮЧЕН"
sry for didnt notice it before, my eyes lie to me sometimes.
« Last Edit: September 10, 2021, 01:42:18 am by wickated »
The following users thanked this post: StephenR0
Offline AndyC
« Reply #2035 on: September 10, 2021, 08:06:30 am »
Swedish:
      .SYSTEM_Oled_Dim_inSleep = " I sovläge",
      .CAL_ZeroSet = "Nolläge    %4u",
      .CAL_Sampling = "Mäter      %4u",
      .CAL_Captured = "Uppmätt    %4u",
Offline czcymotor
  • Country: in
    • Changzhou Chuangyi Motor&Electric Appliance Co.,Ltd.
« Reply #2036 on: September 10, 2021, 09:05:56 am »
nema 17 stepper motor, nema 17 driver, nema 23 stepper motor, buy stepper motor, small stepper motor, closed loop stepper, 3 Phase Stepper Motor, 2 phase stepping motor.
3 Phase Stepper Motor, nema 23 stepper motor, nema 23 stepper
Online DavidAlfa
« Reply #2037 on: September 10, 2021, 09:21:22 am »
Maybe,  maybe... Maybe someone could send me $1.000.000  :)
It's fine for me, I already said that a thousand times, I'm not doing that, so stop insisting, it's really bad for my patience :D
Wickated, I see, the symbol "Т" was missing from the font script. I'll fix it before the new release. It's a bit messy to do!
Isn't this wrong? Mixing upper and lower case options?
.WakeModes =   { "откл", "СОН", "ВЫКЛ", "все" },
I made more changes to the oled dimmer:
[SLP] option has changed to [ON]. So you have [OFF] [ON] [ALL].
ON mode will be applied in low power modes (sleep and standby), no matter the temperature, as the screen is perfectly readable.
The safety is still there, it will only turn off the screen only in sleep mode, when the tip temperature is below 100ºC.
[ALL] is same as before, enabling the dimmer while running (But never turning off).
Feel free to show your suggestions before I make the new builds.
« Last Edit: September 10, 2021, 10:56:13 am by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #2038 on: September 10, 2021, 10:44:30 am »
but screen off in run mode is still there ?
Online DavidAlfa
« Reply #2039 on: September 10, 2021, 10:53:26 am »
Re-read the post  :D.
Offline wickated
  • Country: ru
« Reply #2040 on: September 10, 2021, 10:56:42 am »
no it isnt. cuz actually those are two "off" words(but with different additional meanings. off stands for "disable" and OFF also means "shut down") and it looks like "off" and.. "off", so it had to be differed in that way - "off" for a feature and "OFF" as a mode state
« Last Edit: September 10, 2021, 11:01:01 am by wickated »
Online DavidAlfa
« Reply #2041 on: September 10, 2021, 11:00:40 am »
So"откл" is different from "ОТКЛ", or "все" from "ВСЕ"?
Offline wickated
  • Country: ru
« Reply #2042 on: September 10, 2021, 11:07:24 am »
yep - small should be off and on for feature and big for iron states. "все" is ok for "all possible variants" , "ВСЕ" is not used afair, but if is it would mean all 3 iron states slp,sby,run only.
nvm, ive seen u minimized possible text usage and same words linked across all menus, so ill recheck after new features added to build.
p.s. also i had to mix abbreviations in a weird way and delete spaces or points just to make a clear and readable view.
Online DavidAlfa
« Reply #2043 on: September 10, 2021, 11:10:02 am »
Yeah, I took existing parts for the dim modes (OFF, ON, ALL).
Wouldn't be strange if I did it wrong, so please check them:
.dimMode =     { "откл", "ВКЛ", "все" },
.dimMode =     { "AV", "PÅ", "ALLA" },
Offline wickated
  • Country: ru
« Reply #2044 on: September 10, 2021, 11:26:09 am »
jajaja
so here fun part begins. "ВКЛ" stands for ON, so it logically fully duplicates "all" and is unclear.
so i actually prefer SLP instead of ON (SBY if more accurate, i guess screen actually start dimming on SBY state, am i right?)
Online DavidAlfa
« Reply #2045 on: September 10, 2021, 11:37:01 am »
I'll use "СОН" then. Or which of the 1000 russian versions :D?
« Last Edit: September 10, 2021, 11:41:06 am by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #2046 on: September 10, 2021, 11:41:19 am »
I'll use "СОН" then. Or which of  the 1000 russian versions of it :D?
yeah it should be ok  :-+
p.s. chinese room in action
Online DavidAlfa
« Reply #2047 on: September 10, 2021, 12:15:51 pm »
New builds available (21-09-10). Updated operation manual.
« Last Edit: September 10, 2021, 01:05:50 pm by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #2048 on: September 10, 2021, 02:26:52 pm »
loaded new build, got some strange results. offset is BELOW zero
Online DavidAlfa
« Reply #2049 on: September 10, 2021, 02:35:40 pm »
I see nothing wrong. What does that picture explain?
