Author Topic: Stencil holder  (Read 7250 times)
Offline DagoTopic starter
    • Electronics blog about whatever I happen to build!
Stencil holder
« on: September 16, 2014, 08:35:15 am »
I'd need a stencil holder for small time prototyping work (at work) but I'm having problems finding anything suitable.
Should be something fairly affordable like... 300€ max. or so. Not one of those "production" kind of jigs that cost upwards of 1200€.
I have experience with this http://www.beta-estore.com/rkuk/order_product_details.html?p=64 and it's ok but a bit fiddly so I wouldn't mind trying out something else.
Can you recommend me any stencil holders?
Preferably from EU.
« Last Edit: September 16, 2014, 08:42:17 am by Dago »
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline tggzzz
Re: Stencil holder
« Reply #1 on: September 16, 2014, 09:08:26 am »
Preferably from EU.
For prototyping, you might just consider the quick'n'dirty technique with spare PCBs, see https://www.sparkfun.com/tutorials/58
Offline Precipice
Re: Stencil holder
« Reply #2 on: September 16, 2014, 09:17:11 am »
If you've got control over your PCB and stencil, so you can put dowel holes in,
https://www.tindie.com/products/arachnidlabs/pcb-tooling-block-full-grid/
is tempting.
Well, it's tempting me! (No experience with it, but I've got other stencil holders that are variously unsatisfying).
Re: Stencil holder
« Reply #3 on: September 16, 2014, 10:40:47 am »
is tempting.
That looks perfect but it's backordered :| You could always make some guides from PCB that would have the holes that would enable you to position the boards without 2.5mm holes on the boards themselves (which might be difficult on space constrained boards).
Offline jc101
Re: Stencil holder
« Reply #4 on: September 16, 2014, 10:51:24 am »
EuroCircuits have a registration system you can add to boards and stencils when ordering, but they publish the dimensions used...
http://www.eurocircuits.com/ec-solutions/ec-registration-system
With these holes in the right place they also sell a ex-stencil-Fix which can be seen here
http://be.eurocircuits.com/shop/offtheshelf/product.aspx?ano=ec-stencil-fix
It's only 15 euro's and quite handy, and if you use their dimensions you don't need them to also make the boards and stencils.
Offline odingalt
Re: Stencil holder
« Reply #5 on: September 17, 2014, 05:12:05 am »
For cheap I've just used plastic guide pieces (similar to sparkfun's method using spare PCB's) and have had good luck.  Basically my material list is:
-guide piece that is same thickness as your PCB to be printed
-your plate only prototype stencil foil
-some masking tape
I've printed down to 0.50mm with this setup with no problems.
Online tszaboo
Re: Stencil holder
« Reply #6 on: September 17, 2014, 06:32:53 am »
I've used this some time ago, and indeed, this is the amount of money I would spend on a hobby project. It is simple, and does the job, if you have the standard 1.6mm PCB with the mounting holes described by them. The whole thing is made from FR4 btw.
Offline odingalt
Re: Stencil holder
« Reply #7 on: September 17, 2014, 02:41:33 pm »
Cheap stencil holder example in this video:
In this particular case the stencil and plastic holder was purchased from www.quickstencil.com (I'm in the USA).
Offline zapta
Re: Stencil holder
« Reply #8 on: September 17, 2014, 03:49:46 pm »
-some masking tape
Same experience here. OshStencils sells those 1.6mm L shape plastic holders
http://www.oshstencils.com/pricing.php
I later made my own from laser cut 1/16" acryilic, design files are here (three different sizes) https://github.com/zapta/misc/tree/master/prototyping/pcb_brackets
No problem with 0.5mm pitch. Just get good metal stencils, the plastic one are not as great for 0.5mm.
Re: Stencil holder
« Reply #9 on: September 18, 2014, 05:41:45 am »
This is actually work work, thus the "big" budget :)
