For cheap I've just used plastic guide pieces (similar to sparkfun's method using spare PCB's) and have had good luck. Basically my material list is:
-guide piece that is same thickness as your PCB to be printed
-your plate only prototype stencil foil
-some masking tape
I've printed down to 0.50mm with this setup with no problems.
