Hello everyone.
Short intro:
My trusted Razer Deathadder mouse which I've been using for past 7 years finally started to wear out. Scroll wheel encoder and it's microswitch are working very unreliably and plastic body is a bit worn out too. I decided on buying new mouse and I was prepared to spend any amount of money required to buy quality product (If it serves me 5+ years, it's worth it) BUT I am very used to shape of my current mouse. This lead me to buying damaged
Steelseries Sensei mouse on auction for about $10 (incl. shipping) just to check how its shape fits my hand and maybe to salvage some parts from it. In the end I managed to repair it, but I am not sure how...
Product was advertised as "Customer return. Sensor not tracking. Probably damaged laser".
Sure enough, when it arrived it was properly detected by computer, all the buttons were working but mouse pointer wasn't going anywhere. I decided to at least see what's inside. Whole construction is held by four screws hidden under "skates" on the bottom of the mouse.
Inside, there are really only 2 ICs:
PixArt ADNS-9500 optical sensorSTM32F103CB MCUI visually inspected the board for obvious faults but found nothing, expect for quite a lot of flux residue around through-hole components. At this point I noticed that mouse sensor actually moves chaotically when I shine bright light over optical sensor. I was now pretty sure that it's indeed laser illumination fault but using my phone camera I verified that some light was there.
Following first rule of troubleshooting ("thou shalt check voltages") I dug out
sensor datasheet and began measuring. It didn't take me long to find that something is wrong. I checked that sensor was configured to use external 3V power supply but on that rail I measured about 4.4V. This wasn't good as IC's rated max input voltage was about 3.6V. Following the traces I found tiny
SGM2007-3.3 voltage regulator. It was either faulty or something was shorting 3.3V rail to 5V from usb. One way or another i needed to disconnect regulator output pin from the board. After trying to desolder IC from the board and failing hard I cut the package lead. It turned out that regulator was ok and was providing stable 3.3V when disconnected from the rest of the circuit.
Here is when it gets strange. While measuring the voltage I accidentally shorted package lead back to its pad underneath. And this time voltage stayed on 3.3V. Somehow heating up that area of the board must have fixed the short. I don't know if it was a tin whisker or some other contamination of the pcb or maybe the regulator itself was "repaired" by this process but mouse is now working. Not only all components survived overvoltage on the rail but optical sensor is working perfectly again. I didn't want to blob the cut lead with solder so I added short mod wire to nearby testpoint.
Teardown and before/after repair photos are attached below. I didn't include photos of the top side of the mouse because there is nothing really interesting there and I am already hitting 2MB attachments limit.
Fun fact: Sensor uses infrared laser beam focused (or rather - collimated) to a tight beam. Being infrared it is obviously invisible to a naked eye. UNLESS you stare directly into it. Then it's briefly percepted as quite intensely red color. (it's class 1 laser, I am sure I'll be fine)
PS: I still like the shape my previous mouse better. I'll probably order matching encoder and microswitches on ebay and repair it.
