I have a weller fume extractor-WSA-350- that I bought off eBay for $30 and and additional $7 for 3 filters. It works fine, I place it at the back of my Panavise work center and the flux fumes get sucked up without issue. Hunt around and you can get a deal or just DIY.
How well does it actually remove fumes?
And do you have a window to help out (outside ventilation)?
It does a good job and I don't have outside ventilation. The filters are carbon and absorb the fumes. Mojo-chan says the filtering on desktop extractors are crap. It may be the case, but for my purposes and budget, it works fine. Would I like an $800 extraction system? Of course, but it's a matter of champagne wishes and soda budget
Thanks (wasn't sure the carbon filters did much if anything).
And I can definitely appreciate the budget comment.
I'm fortunate enough to have a
Honeywell unit laying around to convert (0.3um filtration, same as professional fume extractors) regarding costs. Hoping the mods would only run ~$100, though about half of this would just be for a
Loc-Line Vacuum hose kit, so I suspect the actual conversion will run even more. Still cheaper than new, but used may become an option at this point, assuming the filters are still good (or it even has any installed). It's also quite large, but installing it on the floor should solve this (routing the hoses are my primary concern, and would rather not have to cut any holes in the desktop).
What you're using seems a
lot easier, requires less space overall, and less expensive. Even with all the guts I need already (just need hose solution and build a suitable enclosure).
Decisions, decisions....
