Author Topic: Big desoldering tool for SMT transformers?  (Read 1976 times)
Offline jrs45Topic starter
« on: February 17, 2022, 08:03:34 pm »
We have to harvest a bunch of SMT transformers from old boards to get us by for a while.  These are 12-pin transformers, about 2x2cm, so a regular iron isn't going to cut it.
Maybe a beefy preheater placed right under it would get the board hot enough to melt the solder?  Or combined with hot-air?
Any recommendations welcome!
Online coppercone2
Re: Big desoldering tool for SMT transformers?
« Reply #1 on: February 17, 2022, 08:31:52 pm »
pictures would help alot, it sounds like a job for a pace soldering tweezer attachment
Offline thm_w
  • Non-expert
« Reply #2 on: February 18, 2022, 12:09:48 am »
Yeah you can preheat to the point of melting the solder, if you don't mind the wait and don't care about any components on the bottom of the board.
Make sure you have good ventilation.
Another option might be the really wide tips: https://hken.rs-online.com/web/p/soldering-iron-tips/5175575
But you need a reasonably high power iron.
Biggest is 28mm so could work: https://www.waveroomplus.com/Pace-1124-1010-P1-SMT-Mini-Tweezers-Tips-Chip-03-x-109-7-x-28mm_p_1618.html
Online coppercone2
« Reply #3 on: February 18, 2022, 12:25:08 am »
You can also get copper wire/rod that fits into your soldering iron and bend it into the correct shape to make a ghetto pace like extraction tool, possibly filing the wire after its bent for the right form factor. Just keep in mind it will contaminate with copper and have a short shelf life and it will be hard on your soldering iron.. however unless you are running a pro repair shop it might be useful.
« Reply #4 on: February 18, 2022, 01:56:23 pm »
Thanks!  Here's a photo.1417903-0
Each set of terminals is just over 2cm (2.2cm).  I did try a preheater but it's too slow.
Looks like wide irons is the way to go?  The Pace MT-100 tweezers with the special tips look promising, but I'm not sure if the tweezers can span such a large part.
It might be safer to just get a couple of big irons with wide blade tips.  The Hakko one posted is discontinued, sadly.  Maybe something like a pair of T12-1404.  I'll have to dig around I guess.
Offline Shock
« Reply #5 on: February 18, 2022, 02:58:11 pm »
Solder low melt alloy (chip quik) to the pins while underside preheating and hot air if needed to lift.
If you have some copper stock you can diy blade tips. Drill a hole in two blocks and use two cheap irons that use solid core tips. Cut the excess tip off bang it into hole in the block. Put it back on the iron and apply lots of solder to the downside edge. Use preheating and some flux on the board.
The height also might prevent tweezer blades, on the old Pace TT65 tweezers you could just flip them around and bend them to suit or drill a hole and bolt on some copper cut to shape (modify them while removed from the tweezers of course).
« Last Edit: February 18, 2022, 03:20:54 pm by Shock »
Offline thm_w
  • Non-expert
« Reply #6 on: February 18, 2022, 11:48:18 pm »
All of the "T12" stuff is technically discontinued. They've just changed it to "T15". So if you see a T12 tip for sale on line its mostly clones.
If you want ultra low budget: two T12-1404 clone tips and two KSGER stations.
If you have Hakko stations already, and higher budget, official T15 tips: https://www.digikey.ca/en/products/detail/american-hakko-products-inc/T15-1403/6228866
If you have other stations, then check what they offer.
I assume you are willing to break off those capacitors on the left hand side to get the large tip in there.
Offline jpanhalt
« Reply #7 on: February 19, 2022, 12:07:17 am »
Assuming you can destroy the boards, one approach is to use a soft propane flame on the back side.  I have unsoldered RF components and their fully soldered shields that way. You can also snip and saw/drill the board so the smaller pieces can be removed.
Offline jonpaul
« Reply #8 on: February 19, 2022, 01:38:27 am »
Metcal irons large blunt tip.
Or cheap  Chinese vacuum pump irons, $13
Jon
Jean-Paul  the Internet Dinosaur
Offline bdunham7
« Reply #9 on: February 19, 2022, 02:11:39 am »
You might consider taking a large QFP hot air nozzle, cutting off and sealing two of the four nozzle sides and using that with a preheater.  If you got the right size nozzle, you could easily melt the solder without significantly heating the transformer and the missing sides of the nozzle would give you space to grab the transformer with a customized pliers of some sort.
https://www.techni-tool.com/product/821TI126-A1126B?gclid=Cj0KCQiApL2QBhC8ARIsAGMm-KG9cz--YjKL049qTy66Ynq6N6ZDoC7HdIp12OS9bPG65-jrODtvtckaArQEEALw_wcB
« Reply #10 on: March 11, 2022, 07:21:21 pm »
For anyone stumbling upon this thread, and wondering what the solution was, a big wide tip like this worked beautifully:
https://www.tequipment.net/Pace/1130-0502-P1/Tips/
Flux helped, of course, as it always does.
Offline Shock
« Reply #11 on: March 11, 2022, 07:51:16 pm »
Did you use two irons or just go side to side? Yeah flux and preloading the tip with a little solder helps, you get a quicker thermal bridge that way so it dumps heat through the legs more efficiently.
« Last Edit: March 11, 2022, 07:57:32 pm by Shock »
« Reply #12 on: March 12, 2022, 11:53:48 pm »
Just one side at a time, worked well enough and saved me the $$ from buying another iron.  Just lifted the side slightly, moved to the other one.
