@tookiThanks for all the explanations and advice, very kind
Regarding the power supplies for medical use, they should be these, I wonder if the various QUICKO or KSGER have such high quality power supplies inside, given the cost I don't think so, yes as you explained to me the power supplies on digikey that I had shown you previously should also be fine.
I think the 150w power supplies are not good because the C245 tips work at 8A
Power (W)=24V×8A=192wPower supplies for medical use:
https://www.digikey.it/it/products/detail/mean-well-usa-inc/RPS-300-24/7706053https://www.digikey.it/it/products/detail/mean-well-usa-inc/MSP-200-24/7705189Sockets and switches:
https://www.digikey.it/it/products/detail/qualtek/723W-X2-03/245546https://www.digikey.it/it/products/detail/e-switch/RA1113112R/3778055https://www.digikey.it/it/products/detail/molex/2181130202/14309339https://www.digikey.it/it/products/detail/molex/0190030032/3186506https://www.digikey.it/it/products/detail/tensility-international-corp/54-00064/6206245Regarding the fuse holders at the output I didn't understand exactly which one I need, in any case I don't have other soldering irons, so I have to wire all the cables without soldering.
Fuse holders:
https://www.digikey.it/it/products/detail/w%C3%BCrth-elektronik/696103201002/7244556https://www.digikey.it/it/products/detail/schurter-inc/8601-2001-08/2647189https://www.digikey.it/it/products/detail/mpd-memory-protection-devices/BF310/8119220I was evaluating carefully whether this type of configuration is convenient, the power supply costs about 60€/70€, the controller 40€ / 50€, plus the aluminum case, the power supply is always usable in the end since all the controllers work at 24v.
Did you explain to me that there is a risk that it won't work ? the same controller is also sold on Aliexpress, there are no reviews about it. So it is not clear if it is compatible with the original JBC T245 handles
In the description it says: T245 soldering tip and handle compatible JBC 245 soldering iron tip and handle.
So any JBC 245 tip and handle should be fine.
https://it.aliexpress.com/item/1005005431966064.htmlDoes the heating power of the soldering station also depend on the controller ? Or is a quality tip and a good power supply enough ? I mean this, I spend 70€ for a quality power supply, 40€ for an original JBC tip, but then if the controller is poor does it affect the heating performance during soldering ?
Yes, obviously a Chinese clone will never have the construction quality of an original JBC soldering station, the Jabe UD-1200 seems well built, on Aliexpress it costs 180€, it is 118€ less than the JBC BT-2BQA, the guy who reviewed the station also writes here on the forum, he seems very competent, then I don't know, there is always a risk.
The Jabe UD-1200 and the AIXUN T420/T435 do not have the T3A problem, the tips are connected to the ground, both have a linear transformer inside that is free from these problems, they are also compatible with the original JBC handles, if in the future the handle breaks it is very easy to find the replacement.
Sorry Google Translate does not help me, 3 meter stick regarding AIXUN what does it mean ? Is the handle too long ?
For now I am happy with a C245 clone tip, the original costs about 40€, I am aware that the quality is not comparable to the original, some clone tips are at least decent.
Reading this discussion I saw that you have an Ersa i-Con Nano, it is cheaper than the JBC, even the tips are found at lower prices, makes it very interesting.
https://www.eevblog.com/forum/reviews/ersa-i-con-nano-and-nano-mk2-differences/msg5655303/#msg5655303I was also evaluating the GVM H3, but the same reviewer found the cables inside reversed from what I understand, other users have not had the same problem, the transformer seems undersized, it lacks a bit of power.
https://it.aliexpress.com/item/1005001382618513.html-------------------------------------------------------------------------------------------------------------------------------------------------
T245 soldering station how I made one
