Hello all - here I found interesting approach with lots of reality incorporated in this SmartDispenser - NO AIR !!
http://gentec-benelux.com/airfree/ LDS9000 et SmartDispenser
Sturdy precision machined screw and precision motor assure zero backlash during operation which eliminates any leak in the hydraulic line chance of pressure loss.
The stepper motor is directly engaged with the screw eliminating lags and backlash, and is preventing any chance of pressure loss.
Patented Precision machined Piston Stabilizer holds the piston straight in the reservoir, eliminating any chance of pressure loss.
PosiLok™ Quick Release threaded hub and piston allow zero slippage between the piston and drive rod, eliminating any chance of pressure loss.
NoFlex™ Linear Drive Technology gives you the accurate and repeatable method of positive displacement you want without the headache of pneumatic systems. There is no need to flush chambers or valves. Formulations stay untouched in safe, silicone-free barrel reservoirs with this revolutionary new system. You can change fluids or volumes with ease. Unlike AirPulse™ machines, this intelligent dispensing system knows the barrel size, volume and the dispense rate. The result: you get a process control that is unachievable with AirPulse™ systems. profitability.
SmartDispenser™ uses air-free, linear-drive dispense technology to achieve the highest repeatability when dispensing assembly fluids. This technology allows manufacturers to establish one dispense program globally, with no change to fluid deposits. By standardizing dispense programs per product, manufacturers reduce the cost of product validation. The technology also eliminates fluid waste, rework, rejects, and costly air compressors, thus maximizing
By integrating the Windows 7 platform into its technology, each SmartDispenser™ system can be networked to a desktop, laptop, smartphone, or another SmartDispenser™. This technology gives you the ability to monitor live video feeds and real time production data, and enables.
