Many households must have tons of these small AC/DC for cellphone chargers lying around, just found out my old Ericsson cellphone charger from mid 90's I guess, and it is badly crushed and cracked while at the bottom pile of unused electronic junks.
I'm aware there are many of these AC to DC adaptor teardown/discussion threads in this forum, quite boring since almost all are ended up bashing the low quality stuffs made in China, then I thought why not post yet another one but this time made in Finland.
Comments :
- Designed with fully discrete components based, no custom switching chip, the only ic is LM358 soic op-amp at secondary side.
- All bottom PCB components have those tiny "glue" spots oozed out at their side, its to hold them when in solder bath, just watch closely at the close up shots.
- All electrolyte caps are quality caps made in Japan by Nippon Chemi Con with KMG type.
And yes, its still fully working fine with good regulation and as expected with pretty good ripple too.
OK, I will just let the attached photos below to speak for it self.
Enjoy.
