that one does i think, it looks like a clone of a weller - atleast the tips look that way.
it's far to expensive though,
i know you already know this, but if your spending over 20€ you really want all-in-one cartridge tips like T12 or JBC.
Found the full station on TME.eu (
SP-80B), and it definitely looks to be a clone of the Weller WD1 & WSP80* IMHO. There are also Chinese made LT series clone tips available now as well (i.e. eBay).
* For disclosure, I own both as well as the WMP and the stop-n-go stand that allows me to use the full range of setback features (without it, a timer is all that's useable)....costs of JBC... and other options...
Regarding costs, a new
WP80 (newer version) is more expensive than either a
JBC T245 or
Hakko FM-2027* handpieces.
And regarding tips, Hakko's would be the way to go as they're top quality and the common profiles (chisel, hoof, ...) are less expensive than JBC's, and are on par with the Weller LT series tips not made in Bosnia (BTW, Bosnian made tips have ~ a 30% failure rate IME). The US, German, or Japanese made tips do not have this issue, but they do cost more.
For cheaper than this ^ but still get decent stuff, you'll have to go with used.
* There's currently an open box version that includes the stand (switched type that can connect to your DIY station for full setback features), and a brass wool cleaner. New is $20 more. Oh, and this is before the 6% off for EEVBlog members for anything you buy from them.All this said ^, you'd actually be cheaper to just buy a Hakko FX-951 IMHO as by the time you get all the pieces/parts (i.e. transformer, enclosure, and stand), you'll likely be at or even over the cost of a new one (assuming you're in the US/CAN as your location isn't listed below your userID).
Oh, and these have a manufacturer's warranty.
Used for the iron and stand could possibly get you around the cost of the demo unit, but it may be a long wait.
The only other suggestion would be to get a T12 soldering station kit, a suitable SMPS PSU that will fit (24V @ 3A), aluminum enclosure, stand and tip cleaner.
Previous post that has links to this stuff.
The handle that comes with the T12 kit or ready-made station (also linked) will use genuine Hakko T15 series' tips (T15 replaced the T12 series, though I suspect it was really just a P/N change to differentiate the genuine article vs. the clone/fake T12 stuff that's available).
