Author Topic: Shockingly piss-poor USB power supply  (Read 29688 times)
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
Re: Shockingly piss-poor USB power supply
« Reply #25 on: January 04, 2012, 08:07:05 am »
Is the nokia also a one transistor power supply?  ??? Or does it have surface mount components on the back?
What you see is the entire circuit.
It's really strange: there is no trace of mains filtering components.
The Samsung chargers  in the other photos have at least a bridging capacitor from secondary to primary (the blue one), which in my experience is mandatory to pass CE testing with ungrounded power supplies.
I cannot believe that ASTEC, a reputable power supply manufacturer, could made this unit...
Are you sure it is not a fake one?
Best regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Jon Chandler
    • Throw Away PIC
« Reply #26 on: January 04, 2012, 08:37:12 am »
I stand corrected on the Nokia supply.  There are SMT components on the back of the board include a couple transistors of some type and maybe 15 resistors and capacitors.  Sorry I did not notice these before.
A curious feature of the board is a bunch of solder dots where there are not component leads to be soldered.  Look at the bottom center and upper right corner in the picture below.
Offline Rufus
« Reply #27 on: January 04, 2012, 11:04:28 am »
Presumably intended to reduce trace resistance by adding solder. The skinny serpentine tracks on the secondary side are unusual and presumably act as fuses.
To me the most curious feature is the resist free triangles which look like the are intended to encourage flash over across the transformer isolation. Some one have a justification for those?
Offline RJSC
  • Country: pt
« Reply #28 on: January 04, 2012, 11:22:00 am »
Hmm... Still crappy anyway, I don't see any feedback loop.
Offline Bored@Work
« Reply #29 on: January 04, 2012, 01:18:22 pm »
It is not mandatory, and there is no CE testing. The CE mark is a self-certification that you claim the product is in line with all mandatory regulations. Of course, the fun starts with figuring out the relevant regulations first.
When it comes to emissions, there is also no regulation how you keep your device below the required levels, just that you have to. A Y cap is just the easy way out. But you find high quality SMPS' without a Y cap where they manage to keep emissions within the required levels.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #30 on: January 04, 2012, 01:26:37 pm »
i dont see any problem with the china adapter circuit, in fact i like the design... simple
simple design will pay. you should be aware of power factor correction which is poorer with this "simple" design. this will effect the line in the viccinity and interfere with other devices. with no optimization, this smps like design will probably have higher switching loss, which is not very good... source=wiki
Offline thilo
AW: Shockingly piss-poor USB power supply
« Reply #31 on: January 04, 2012, 07:52:38 pm »
I've got a docking station for my phone that has the power supply connected in parallel too. What's the proper way to do it? Can I just disconnect the USB V+ pin and power the docking station exclusively from the external power supply?
    • Mike's Electric Stuff
« Reply #32 on: January 05, 2012, 12:33:35 am »
Here's a vid showing a more acceptable PSU
Day Job: Mostly LEDs
Offline Greg J
  • Hi there
« Reply #33 on: January 05, 2012, 12:43:35 am »
You forgot to test it under load and do all the measurements :P
It looks more solid, but does it perform any better ?
Take It EV
Offline don.r
« Reply #34 on: January 05, 2012, 01:36:54 am »
You inspired me to pick up a few from the local charity shop. I looked for screw held cases and came away with a 5v/1amp switcher (Audiovox branded) that holds to 4.5v at 800ma and a couple of linear supplies, one 9V at 500ma which consists of a rectifier, cap and xformer and a fairly hefty (1kg!) wall wart which outputs 15v @ 1650ma with a regulated output. All that for $2.50...  ;D
Offline Fraser
« Reply #35 on: January 05, 2012, 12:57:22 pm »
Prior to this thread, I was browsing my usual ebay equipment suppliers store and noticed he was selling 140 (yes 140) 240V to USB 5V 1A adapters with a start price of GBP9.99 + free postage. they look a decent type from the outside. The catch..... the 3 pin UK plug part that attaches to them is missing. As a project part the lack of the plug is of no consequence so I placed a low bid.
I won 140 USB power supplies for GBP9.99  :o
What the heck I am going to do with 140 of the little blighters, I have no idea ! I will take one apart to see how well it is made. If they are decent they may have been a bargain.... if not...oh well you don't win them all  ;D  My wife will (not!) be pleased when a large box of 140 little boxes arrives  ;)
Offline Bored@Work
« Reply #36 on: January 05, 2012, 03:27:22 pm »
I have 20 or so small project boxes sitting on the shelf. They came as a lot of 25. It was cheaper to buy the lot than a single one for a particular project :)
Regarding USB power supplies. I had an opportunity to look inside an Atten AT1501D power supply for mobile phone repair http://www.atten.com.cn/ShowProduct.aspx?G=2&productId=739
Well, not too pretty.
A steel case, but no PE/Ground connection, just a two wire L and N mains cable, permanently attached to the unit. And nothing inside the unit that looked remotely like double isolation. A tiny transformer 220V (not 240V) primary and 20V and 10V secondary windings.
A funny mixture of analogue display (current) and digital display (volts), although the analogue current display might help for some repair jobs.
An LM723 for the adjustable output, with an 2N3055 in TO3 bolted to the case without an additional heatsink. The USB 5V might come from an 7805 inside the case. A heatsink and a cap, supposed to be well cooked by the 7805 due to its proximity to the 7805, prevented me to see the exact type. A Holtek IC (OTP MCU?) in a DIP socket (luxury ;) ) to drive the voltmeter display and to drive (luxury, luxury  ;) ) a beeper. No idea if/when the beeper beeps.
The pot for the voltage adjustment was a single turn pot. The output range can be switched between 0-5V and from 0-15V.  I.e. there isn't much granularity in the 0-15V range. I think I spotted a protection diode at the output.
USB A socket on the front to power the mobile phone from the power supply, and a USB B socket on the back is supposed to go to a PC. The USB data lines are supposed to be connected between the back and the front, while the power to the front is supposed to come from the PSU. Although I can't rule out that the PSU power was just connected in parallel with the USB power from the PC.
A strange little power supply, and the missing PE/Ground connection without double isolation is IMHO a show-stopper.
« Last Edit: January 06, 2012, 09:09:11 pm by BoredAtWork »
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #37 on: January 05, 2012, 06:47:34 pm »
http://www.pcbheaven.com/userpages/how_cheap_is_a_power_supply/
via HackADay
Makes you think a bit :P Just because a power supply "works" doesn't mean much.
Offline DavidDLC
« Reply #38 on: January 05, 2012, 06:55:27 pm »
Don't get confused with the phone chargers.
Those phones chargers are designed to do what they have to do, no matter the number of transistors or ICs on them.
Some of them are tested under temperature chambers and more functional test before they go to mass production, even if third companies are doing the manufacturing.
Of course the cell phone companies are always looking for ways to reduce cost and still get the same results, that is why some designs have only one transistor. Most of the beauty happens inside the phone anyways.
Offline NiHaoMike
    • Facebook Page
« Reply #39 on: January 06, 2012, 04:22:45 am »
As a comparison, here's a Nokia charger.  I should note that the Samsung chargers are screwed together and can be opened without much trouble.  The Nokia charger was glued together and required a brute-force approach to open it.  After looking at the circuit board, this may be more than a coincidence!
That adapter may look like a fake, but several genuine Nokia adapters I have taken apart look very similar. Unlike most adapters, they are basically current sources with voltage limit, which is very useful for charging batteries or powering LED arrays.
Offline Fraser
« Reply #40 on: January 09, 2012, 04:37:49 pm »
My box of 140 USB power supplies arrived today  :)
Wife wasn't too chuffed to see them  :(
These power supplies are the type that have a common power block and optional connectors to suit various countries, so making the unit a universal travel charger. I paid GBP9.99 inc postage for a box of 140 as they are missing the connectors. Thats 7p each   :o  I wasn't expecting much but they have turned out to be quite interesting. The unit produces 5V @ 700mA according to the label but I have not tested one yet.
The units look well put together and helpfully have tri-wing screws holding the case together instead of the welded construction so common these days. Upon opening the unit I was horrified to see a single transistor sitting amongst several other components.......but I jumped to an incorrect conclusion. Upon turning the PCB over I found a cluster of SMT components including a 'TH2267.1' 8 pin chip. I believe this chip to be the switching controller for the transistor. The switching transistor drives a decent looking little ferrite transformer. The transformer appears to have some sort of feedback winding that goes to the TH2267.1 chip (for output regulation?).
At the secondary of the transformer a single diode is used to rectify the ac and this is smoothed with a 470uF capacitor.
I did a quick search for the TH2267.1 and had quite a surprise when I found that many people wanted the same information but the chip is custom and Melexis Will not release any information at all, including its function ! See below from the Melexis FAQ site:
FAQs by Topic
TH2267.1
 Q: Do you have anybody datasheet or same information about IC "TH2267.1" 8pins, SOP-8.
A: The requested datasheet can not be provided to you because the TH2267 is a custom specific product and therefore not open for everybody like our ASSP's listed on our web site.
Q: Why won't you guys make a datasheet available for this TH2267.1 chip. It's used in lots of Nokia cellphone chargers and a bit of info would help a lot of people who want to repair these things!
A: For customer specific parts like this one we have a contract with our customer in which is stated that we are not allowed to disclose any information without their permission.
Q: Is it possible to inquire about the approximate price of your product TH2267.1?
A:This is also confidential information which we cannot disclose.
Q:Can anybody please tell me what this IC TH2267.1 is doing at all?
A:We are not allowed to even disclose the function of the IC.
Finally the design looks decent enough, but the PCB track layout looks a little wild for my liking. The SMPSU case has several safety markings and indicates that the unit was manufactured in Germany. I was hoping to modify some of the 140 units for other usefull voltages for use in little projects. It would appear the TH2267.1 may have burst that balloon  :( I will try to work out its functionality via teh circuit around it. I have a few that I can risk in order to experiment on the design  ;)
All good fun  ;D
Apologies for the overexposed pictures, they were taken in a hurry.
Aurora
« Last Edit: January 09, 2012, 04:40:22 pm by Aurora »
Offline thilo
« Reply #41 on: January 09, 2012, 04:46:05 pm »
What's the purpose of the four diodes then? They're arranged as you'd expect in a bridge rectifier.
Offline oPossum
« Reply #42 on: January 09, 2012, 04:56:27 pm »
The bridge is on the primary side and converts the 100 to 240 VAC to high voltage DC.
The DC is chopped by the switching transistor, and sent to the primary of the transformer.
The single diode is on the secondary side of the transformer.
The single switching transistor and single diode on the secondary strongly suggest a flyback topology. There is no need for more diodes - would not improve anything.
Two switching transistors and a half or full bride on the secondary would suggest a forward converter topology.
Offline IanB
« Reply #43 on: January 09, 2012, 04:59:31 pm »
Sounds like some reverse engineering is in order! It's fair enough though, if a customer has a part custom designed and made for them then it is proprietary. The only company that could possibly disclose information about the part is Nokia.
Offline McMonster
    • McMonster's blog
« Reply #44 on: January 09, 2012, 05:07:06 pm »
I'd love to see that chip decapped and put under a microscope. It shouldn't be too complicated so this and a bit of probing around with a scope could tell really a lot about its function.
Offline oPossum
« Reply #45 on: January 09, 2012, 05:09:25 pm »
Data sheet is the first link on Gooooogle.
th2267.1
Offline Fraser
« Reply #46 on: January 09, 2012, 05:13:38 pm »
DOH !
How did I miss that !   :-[
Many thanks
Aurora
Offline Fraser
« Reply #47 on: January 09, 2012, 10:01:27 pm »
oPossum,
I have just taken a good look at the data sheet you referred me to.
Thanks to you I now have all the information that I need to make use of these little SMPSU's.
Unlike the SMPSU detailed at the start of this thread by the OP, these German SMPSU's use a sophisticated ASIC with all manner of control and safety features....one extreme to the other I think  :)  The transformer has a feedback winding and a separate winding to power the TH2267.1 after the start up sequence. Quite a decent smpsu after all  :D
Thanks again for making me realise I had missed the important datasheet. With the FRIWO part no. I was able to find the original source of the datasheet. Obviously FRIWO were willing to release the information when the manufacturer was not able to do so due to an NDA.
Offline gxti
« Reply #48 on: January 10, 2012, 03:22:04 am »
No need to get excited about an obscure custom part; switcher ICs are very common. One company "Power Integrations" has dozens of different product lines for flyback, forward, non-isolated, low parts count, etc. all available through Digi-Key with very good datasheets. I'm currently weighing my options for a project, it's between design my own around an IC (fun, expensive, dangerous, hooray) or buy a box of plug packs on ebay like Aurora did :-)
EDIT: two of the pictures on Jon Chandler's post on the second page have PI chips, for example
« Last Edit: January 10, 2012, 03:23:49 am by gxti »
    • Throw Away PIC
« Reply #49 on: January 10, 2012, 05:19:00 am »
... I'm currently weighing my options for a project, it's between design my own around an IC (fun, expensive, dangerous, hooray)...
I considered building a supply for a project, but most of the chips depend on a specialized transformer.  I found some designed for specific ICs, but they're about $15 each in small quantities.  Makes recycling $1 supplies from the thrift store look pretty good.
