Just got a 80V Kobalt mower with two knock off 80V chinesium batteries (long story).
BMSs on the two batteries are okay, cells are balanced and happy. The batteries are also charging no problem on a Kobalt charger.
Issue is when I use the battery in the mower after 3 sec, I got the beeping and the tool shut off...
It already happened in the past...
https://www.eevblog.com/forum/reviews/greenworks-60v-battery-ohm-terminal/I am assuming that the bidirectional omega line is making the tool upset and cuts the power off.
This pisses me off immensely because clearly it a proprietary restriction.
I am trying a new approach...
I bought the cheapest 80V Kobalt batteries I could find on ebay and then here what I have in my mind...
1) separate the BMS board from the cells
2) try to simulate the battery to make that BMS happy
3) install everything INSIDE the tool, so that the tool needs only 80V (Bat+ and Bat-) from outside to run... no more omega line...
In other words instead to go crazy and simulate with a µC the pulses on the Omega line, I will use a disconnected Kobalt BMS/Battery board to create it for me...
some baby steps tonight...
Pulling 4A from chinesium battery... with nothing connected on the omega line...
![](https://www.eevblog.com/forum/reviews/set-the-80v-battery-and-tool-kobaltgreenworks-finally-free/?action=dlattach;attach=1832416;image)
works....
Board inside the mower, potted to protect it from water/rain.... makes sense...
![](https://www.eevblog.com/forum/reviews/set-the-80v-battery-and-tool-kobaltgreenworks-finally-free/?action=dlattach;attach=1832422;image)
1 - Cabling to the brushless motor... 3 phases? Why 3 thick wires?
2 - Negative and omega line (blue cable)
3 - Positive cable
Wish me luck...
