For my work, I currently use 60/40 solder wire and it seems to work fine with regards to finishing. I have had some problems with inconsistent cleaning of the residue. I want to move to a no-clean variant of solder wire. I haven't had the occasion to use 63/37 wire before.
We use leaded solder wire for long term product reliability and to prevent whisker growth related issues with lead free Ag based wire. Soldering is primarily done manually (hand soldering) with little to no automation since production volumes are typically low. Chipquik no-clean leaded flux is used to aid with setting and soldering SMD components. Compliance with RoHS and lead free regime
is not an immediate concern for now.
I looked up no-clean Sn/Pb options from Kester (for no reason other than having heard and read more about it than others) and found 245 and 275 series with SN63PB37 combination of wire in various diameters between 0.3-0.8mm to match my requirements. If there are other equally good or better options from other brands, please do chip in. I have read lots of positive reviews of 63/37 245 series wire but very few of 275 series.
My confusion, and hence the reason for this thread, is related to following issues:
1 - What percentage of flux is recommended for solder wire to allow adequate whetting for SMD components (smallest size being 0805 resistors, TQFP-80, TQFP-100 ICs, etc) and solder flow with through-holes but not too much which may cause a mess with residue. I see 1.1%, 2.2% and 3.3% options being available for both series.
2 - Datasheets show the 275 having higher leakage resistance than 245 after soldering but I am not sure what flux percentage it is valid for. What is the difference between the 245 and 275 series in practice?
3 - What difference should I expect with regards to workability and finishing (shine, flow, etc) of 63/37 vs 70/30 and 60/40?
If you have got hands-on experience with both series, I would appreciate it if you can share your experience.
I plan to order a sample roll to test before committing to any particular brand/series. Please also share recommended procurement sources for your wire recommendation in the US. I have found Digikey and Mouser pricing to be way too expensive.
