Author Topic: Another epic teardown begins....  (Read 8565 times)
    • Mike's Electric Stuff
« on: March 08, 2016, 12:57:46 am »
Leica TCS SP2 Laser Scanning Spectral Confocal Microscope Part 1
« Last Edit: March 08, 2016, 09:27:09 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Offline BravoV
  • +++ ATH1
Re: Another epic teardown begins....
« Reply #1 on: March 08, 2016, 04:25:14 am »
Great toy Mike, looking forward to watch the whole teardown.  :clap:
Offline AF6LJ
« Reply #2 on: March 08, 2016, 04:37:40 am »
This is going to be Good
Sue AF6LJ
« Reply #3 on: March 08, 2016, 09:27:32 pm »
Part 2
Offline BravoV
  • +++ ATH1
« Reply #4 on: March 08, 2016, 10:06:41 pm »
Feeling sad seeing that solid state diode went poof.  :'(
Thanks Mike !  :-+
Offline RobertGogol
    • my adventure with Electronics and Music
« Reply #5 on: March 08, 2016, 10:29:02 pm »
Very interesting teardown, thank you :)
« Reply #6 on: March 08, 2016, 11:02:58 pm »
Thanks Mike !  :-+
One laser dies, another is reborn - and the yellow HeNe looks much nicer - the DPSS green just looked like a slightly pale 532.
« Reply #7 on: March 09, 2016, 08:48:20 pm »
Part 3 :
Offline German_EE
« Reply #8 on: March 09, 2016, 10:10:35 pm »
First time I've seen a yellow laser.
Warren Buffett
Offline AF6LJ
« Reply #9 on: March 09, 2016, 11:51:05 pm »
The optics in that are great.
Sue AF6LJ
Offline BravoV
  • +++ ATH1
« Reply #10 on: March 10, 2016, 04:50:47 am »
Let alone the electronic and optical parts, looking at those so many custom machined aluminium blocks alone is quite scary when thinking about it's production cost.
Offline AF6LJ
« Reply #11 on: March 10, 2016, 02:19:32 pm »
I get a nose bleed just thinking about the cost...
Sue AF6LJ
Offline Turbon
« Reply #12 on: March 10, 2016, 02:27:05 pm »
Just give me one and I'll folow :)
Regards
Offline dexters_lab
« Reply #13 on: March 11, 2016, 08:34:25 am »
really interesting item there & love the engineering involved
shame the pump diode died in that laser, but green lasers are not hard to come by now. The argon and the yellow hene are nice though, there is something about glassware that makes things look so cool!
looking forward to seeing the acoustic filtering stuff
« Reply #14 on: March 11, 2016, 10:11:47 am »
True, though this is a subtly different shade of green....
« Reply #15 on: March 11, 2016, 10:56:42 am »
Part 4
Offline AF6LJ
« Reply #16 on: March 11, 2016, 05:34:07 pm »
Oh GOODIE.... :popcorn:  :-+ :-+
Sue AF6LJ
Offline wkb
« Reply #17 on: March 13, 2016, 06:45:46 pm »
My guess is that Leica for their camera & optical business have ample CNC capability. With low prouction numbers CNC machining a couple extra bits is most likely the most cost effective approach.
German Maschinenbau at its very best!
Offline wkb
« Reply #18 on: March 13, 2016, 07:15:10 pm »
Having watched Mike's teardown of the Leica with fascination I remembered I tore down one of these Melles Griot HeNe lasers like 5 years back.
The actual laser tube is fitted in an aluminium tube with some thermoplastic gooey.  Getting the tube out therefore involved sticking the whole thing in the kitchen oven (..I wasn't married at the time  :popcorn:..) to melt it down.  Bit of a stink but he..
The whole procedure is documented in fotos and videos at https://wkb.home.xs4all.nl/Laser-hacking/
The videos show the defective tube.  I was told by a laser guru (the author of the LaserFAQ btw) that the tube exhibits heavy sputtering which is the reason it never starts.
« Last Edit: March 14, 2016, 07:09:35 pm by wkb »
Offline Kilrah
« Reply #19 on: March 13, 2016, 08:06:02 pm »
RGBY+Galvanometer - isn't that all you'd need to make a fancy laser quadricolor video projector? :P
Not enough power though...
