Author Topic: Scope: Instek GDS-1102A-U, Rigol DS1102E, Owon SDS7102, Hantek DSO5102B, Other?  (Read 32453 times)
Offline YaksaredabombTopic starter
Update May 10, 2013
I fell prey to the very same "dangerous progression" I was trying to avoid by sticking to the sub $500 range.  Several months have gone by since I first posted this thread and I've ended up with the idea that a scope is a long-term tool, and it wouldn't be wise to buy one the same way I'd buy an TV or other electronic gizmo (heavy preference towards the bare minimum and compromising on features for the sake of price).
My desired specs crept all the way up to the 4-channel, 200MHz range and my budget crept with them - up to the $1k to $2k range.  My leading option today is a used Agilent MSOX2024A for about $2k.
As a result it doesn't make sense to keep posting here when this thread's title and contents no longer match.  I'll write a summary post ("Reply #40") and start a new thread.
Thank you to everyone for your input.  I'm absolutely positive I'll be happier with the purchase I make as a result of your contributions, and I hope they've helped other people too.
Hi everyone.  I have been “lurking” around this site silently for a few months now, having come across it when looking for reviews of the Owon SDS7102.  Since then I have found this to be a very helpful site with lots of bright and friendly people (some of which have their quirks).  I am hoping some of you will share your current thoughts, even though there have been dozens of threads on this topic over the past few years.
Background info:
I have wanted to get an oscilloscope for a couple years now but couldn’t spend the money.  I still can’t spend much money, unfortunately, since it would be for personal use - and therefore must be justifiable to my wonderful but non-technical wife ("Maybe you can just rent one?" haha).
I am trying to stay in the sub-500 USD range if possible, because there are several attractive options in the $800-$1000 range.  If I was convinced to consider spending $700 I'd risk being lured to spend "only a couple hundred more" to get some of the very nice features (higher waveforms/sec, greater memory depth (and higher sampling rate at those depths), better zooming, larger screen, etc).  From there, again I could spend only a couple hundred more to get a much more useful scope with 4 channels or even more nice features.  It's a dangerous progression common to most electronics purchases these days.  I'm hoping to avoid it in this case by nipping it in the bud and I couldn’t really afford it anyways.
On the other hand, I also can’t afford to waste my money by spending *too little*, getting a scope that won’t meet my intended purpose, and either being stuck with it or having to spend even more money to replace it.  Still, it seems like the very low end scopes may have enough functionality to be worth buying one.
Capabilities I think I can get by with:
I've decided 2 channels, 100 MHz bandwidth, and 1 GS/s sampling rate are my minimum requirements as I plan to be working with digital and analog signals up to 20 MHz.
Applications/reasoning for minimum requirements:
One specific project is the MSP430 $4.30 kit and associated DIP uC’s.  I’ve made a system to monitor and control my saltwater aquarium’s water levels but it has a few intermittent bugs and I feel so blind without a scope.  These uC’s have a 16MHz clock.  I’m sure I will want to work with other uC’s too hence the rounding to 20MHz.  I’m also interested in learning how to design simple PCBs so that will undoubtedly open up all kinds of new possibilities (I’ve heard breadboards are only good up to certain frequencies).  If you’re curious I’m looking at seeedstudio’s PCB service.  It starts at 9.90 USD total for 10 small boards which I can actually afford.
Finally, possible product options:
GW Instek GDS-1102A-U (~$500 delivered with case)
http://www.tequipment.net/InstekGDS-1102A-U.html
Rigol DS1102E (~$400 delivered with case)
http://www.saelig.com/product/PSPC017.htm
(deliberately chosen as I don’t want to hack it)
Owon SDS7102 (~$430 delivered with case)
http://www.saelig.com/PSBE100/PSBE100008.htm
(discontinued at tequipment.net interestingly)
Hantek DSO5102B (~$420 delivered)
http://www.circuitspecialists.com/dso5102b.html
And, any other scope a forum member feels like should be on this list.
(Note:  I’m posting this here, including links, because the forum description says “talk about or ask questions for a specific product”.  I’m not necessarily looking for the best deal or where to buy as that might fit better in the Buy/Sell/Wanted forum once I know which scope I want.)
What I am looking for from EEVblog members (and visitors) reading this:
I have scoured the site and read many (though I’m sure not all) of the threads relevant to these scopes.  Like others, though, I’m still having a very hard time deciding.  Further, it seems like as years go by the hardware and firmware have changed – making some older threads less useful.
I think what might be most helpful is if anyone familiar with a *recent* release of any of these scopes (say, purchased July 2012 or later) could share their comments.  Specific things I’m thinking about are screen size/resolution, memory depth, ease of “zooming”, split screen etc.  Firmware usefulness but also more importantly stability.  I want something that will not be prone to locking up (hence I’m hesitant on the Hantek which might otherwise be one of my top choices).
What do you love about the scope?  What makes you wish you could return it and buy a different one?  Which features do you wish it had?  Which features did you think you needed but have actually not been a big deal to have or not have?
Thank you so much for your input!  I hope an updated/recent discussion is useful not only for me but also for the 100’s or 1000’s of people that browse but never write.
Jacob
« Last Edit: May 10, 2013, 07:38:04 pm by jneumann »
My display name changed June 6th from "jneumann" to "Yaksaredabomb"
The following users thanked this post: vmax
Offline tlu
Personally I like the Hantek DSO5102B as I think it is overall the most balanced of the mentioned scope. In my opinion is the most feature rich of the these in terms of the firmware with a decent size screen. With just the screen size factor alone that puts the rigol and the gw-instek out of the question. What lacks the most in this scope is the poor deep memory feature but its fast waveform/s refresh rate kinda makes up for it, although not the fastest but it is very good for this price range.
I've like the Owon as well, but it lacks some of the features that would make my work easier so I opted for the Hantek.
Personally I like the Hantek DSO5102B as I think it is overall the most balanced of the mentioned scope....
Thanks tlu!  Absolutely right about the screen but I've heard the persistant menu on the right can get a little annoying.  Has it bothered you at all?  I've also heard the firmware is "buggy" though very functional.  Has it locked up much on you?  Would you please let me know how long ago you got the scope?
Thanks again!!!
Offline saturation
  • Doveryai, no proveryai
    • NIST
I'd go with the Rigol >>> Instek.  You'll get local warranty service with CSI for Hantek or Saelig for Owon but as you read on eevblog, they've had their share of production defects ontop of firmware issues.  It could already be fixed as of this writing, but such events haven't happened even once to the Rigol 1000 series.  There is a risk of more unknown failures/glitches still down the road.
https://www.eevblog.com/forum/general-chat/hantek-dso5102b-self-bricking-oscilloscope/msg95437/#msg95437
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/review-of-owon-sds7102/msg108638/#msg108638
With a Rigol USA presence, you have higher likelihood in the long term of honoring a warranty, or at least access to factory level repair in the USA.
With Agilent having another set of Rigol's rebadged with Agilent's name, its suggests to me Rigol's quality is rated high enough for Agilent to again put their name on this product line.
What you read on the Rigol spec sheet will most likely happen and build quality is proven [ discussed since 2009, scopes are now 4+years old, with hardly, if not any, complaints.]  It isn't the most ergonomic among the competitors listed, but its proven reliable as a measuring instrument.  The only other scope with such a reputation is Instek, but at higher cost.
« Last Edit: October 17, 2012, 05:34:57 pm by saturation »
Best Wishes,
 Saturation
Offline Smokey
  • Not An Expert
The only one I have any experience with is the Instek.  We have two of them that we use in production, but like I've said elsewhere, I steal them all the time to use for engineering when I need another channel or something.  Since I can't really compare it against the others, I guess this isn't very useful to you, but I've been really happy with the Instek performance.  The deep memory is nice and allows me to window zoom into the 25ns level when I'm triggering on an edge 12ms away.  The screen is about the same size at the 10 year old Tek on the other bench, so it's not bad at all to work with.  There are a lot of preset slots for settings, which I find really useful when you need to have a complex setup for some test to just be able to recall that from a list.  I also spent some time writing a python script that interfaces with the scope through USB.  It takes a couple seconds to dump the full memory, but other than that it's a pretty good remote measurement tool.  Pretty much anything you can do on the front panel you can do through the USB including dumping all the measurements.
I haven't had to send the scopes back for warranty repair, but I did have an Instek function gen die on me and the warranty process wasn't too painful.  They have good presence in the USA at least.  While you are paying a bit more, you are buying the support.  If you know Chinese, you are probably all set, else you might be out of luck.  That probably isn't an issue with the Rigol anymore, but who knows about the others.
That's all I got.
The only one I have any experience with is the Instek....  ...I've been really happy with the Instek performance.  The deep memory is nice and allows me to window zoom into the 25ns level when I'm triggering on an edge 12ms away.  The screen is about the same size at the 10 year old Tek on the other bench, so it's not bad at all to work with.  There are a lot of preset slots for settings, which I find really useful when you need to have a complex setup for some test to just be able to recall that from a list.  I also spent some time writing a python script that interfaces with the scope through USB.  It takes a couple seconds to dump the full memory, but other than that it's a pretty good remote measurement tool.  Pretty much anything you can do on the front panel you can do through the USB including dumping all the measurements....
Thanks saturation and Smokey!  I appreciate the extra input from warranty, reliability, and hands-on perspectives.
I did see saturation's post here (also helpful) and read all the threads:
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/new-instek-scope-gds-1072a-u/msg88610/#msg88610
I also read cybergibbons' post here:
https://www.eevblog.com/forum/general-chat/instek-gds-1102a-oscilloscope/msg55068/#msg55068
cyber may be mistaken about the go/no-go (http://www.tequipment.net/InstekGDS-1102A-U.html) and with Smokey's good experience with a python script I'm not too concerned about cyber's points 1 and 2.  Of course, on the whole cyber says they're "very happy" with the Instek - as does nearly everyone else who posts about it.
It does seem the Instek may have higher quality than the Rigol, with it's better ADCs and 2M memory vs 1M, but the zoom isn't as easy or doesn't really exist and the already small screen (compared to Hantek and Owon) is further reduced by the persistant menu on the right.
Smokey, you said the screen size doesn't really bother you?  The menu on the right doesn't get too annoying?  Also, you mentioned "window zoom".  I haven't seen (or can't remember seeing) any pictures of its zoom function.  Do you mean just changing the horizontal scale after a single-shot or is there actually a split-screen type of thing?  Maybe there isn't but it doesn't bother you.  Thanks again!
I think based on saturation's comments I'm leaning towards Rigol if it's Instek vs Rigol, if only because the $100 savings may be worth it for me.
It's really a shame about the Hantek firmware possibly being unreliable.  I'm not sure where he got his information, but tinhead wrote the wfms/s of the Hantek DSO5062B is just more than 3 times the wfms/s of the Rigol DS1052E (2500 to 800).
https://www.eevblog.com/forum/general-chat/another-ds1052e-thread/msg35459/#msg35459
Elsewhere the Hantek wfms/s is mentioned to be 2000:
http://blog.circuitspecialists.com/product-review-hantek-dso5102b-100mhz-digital-storage-oscilloscope
I've read the hardware in both those scopes is pretty much (or IS) the same hardware in the scopes I'm looking at.  Between that, the larger screen, the fuller firmware feature set, etc I still *want* to lean towards the Hantek.  I do not want to have to hack the thing to unbrick it though.
If anyone who's bought the Hantek recently (since July or hopefully sooner) can give their impression of the current firmware that would be very helpful!
Otherwise it's starting to look like the best choice for me is becoming clear (Rigol).
Thanks again everyone.
Offline tlu
Hi jneumann,
I've had my Hantek for about 2 weeks now and I'm loving this scope. The firmware that came with it isn't the lastest that is on the Hantek website so I have not took the lastest firmware for a spin yet. However, even with the older version of the firmware, this is an excellent scope for its price, features, and large screen.
I have not had any major hiccups with the scope yet. Initially, I thought the scope crashed or froze on me but it was my mistake. I had the stop acquisition button on so it just sat there idle. However, this was not a crash of the firmware by operator error. The fan is a tad on the noisy side in a very silent room but not too loud where I get annoyed by it. Tinhead has a mod to this which is simply changing out the 7812 to a 7805 LDO regulator.
The big screen helps alot as it gives nice visual and adequate colors. You can always hide the right hand menu if need be. I only have it up when I want it to display the measurement data for me. Again, it can be hidden away. Only in FFT mode is when the right hand menu can not be hidden. I did find the knobs to be a little less responsive but than again I'm not at the lastest version of the firmware. I will update soon when I have the time and report back.
tlu
I have not had any major hiccups with the scope yet.... ...The fan is a tad on the noisy side in a very silent room but not too loud where I get annoyed by it. Tinhead has a mod to this which is simply changing out the 7812 to a 7805 LDO regulator.
Thanks for the extra info, tlu!  It is encouraging my risk-taking side haha.  I will leave the Hantek DSO5102B in the running a little longer then, along side the Rigol DS1102E.  The Owon SDS7102 and Instek GDS-1102A-U both seem like good scopes but for now they have moved to the lower half of my list.  Though I like its hardware I don't think I'll like the Owon's menu style or its slow wfms/s (up to 20 or 30 wfms/s vs 800, 2000, or 2500/s).  For this particular purchase I think I'm willing to give up the Instek's quality advantage over the Rigol and Hantek to save an extra $100, especially given that its "effective" screen size is the smallest of all 4 options due to its persistant side menu.
I don't think it would be a deal-breaker for me, but tlu if you have a chance would you please say a bit more about the knobs?  What are you comparing their responsiveness to and is it a small issue only in particular situations or all the time?  I'm curious and maybe others would like to know too.
It could help to know your current firmware version also, as it sounds like maybe by now some of the bugs have been addressed and the Hantek can be seen as a little more robust (or possibly that's just wishful thinking).  If you have a chance to try the latest firmware (and want to) I wonder how that will compare to what it was shipped with.
I really appreciate you taking the time to share what you have, as a recent owner.  It seems like things are changing every few months or even weeks, both hardware and software, so it's nice to get impressions of a "current" unit.
For instance, some seem to think the Rigol has improved quite a bit over the past few years despite carrying the same model number.  Not just firmware but hardware too:
https://www.eevblog.com/forum/general-chat/modern-budget-scopes-just-how-good-are-they/msg141588/#msg141588
As of September 2011 Mark Madel (marmad) didn't seem to think much of the Hantek build quality/appearance.  He also thought it to be the "buggiest" of it, the Rigol, and the Owon.  Oddly, for all it's speed at lower memory depths he thought at 1M memory it was slower than the Owon at 10M.  He did spend 2/3 of the video talking about how nice the software was, superior to the other two scopes in a few ways, but still ranked the Hantek last in the end with it's fast waveform capture rate being perhaps its most redeeming feature.  Hopefully it has also improved much in software and/or hardware in the last year:
http://youtu.be/u7UgKJ8M7LY
Has anyone else been very put off by the scope's cheap "toy" appearance?  I don't think I'd mind a "cheap" appearance nor do I expect the scope to last 10+ years (after all I realize I am looking at very cheap scopes).  If it feels so fragile it won't last a year or that you wouldn't trust it with another person then that might play to the Rigol's favor.  There's the warranty I know but I'd rather not deal with that if I can avoid it.
As of a couple weeks ago tinkerwithstuff did notice some recent firmware fixed an issue he was having last year:
http://youtu.be/-Jl9MNrwFPM
A couple weeks ago one of tinker's commenters said version V2.06.3_0808 fixed an issue they were having.  Maybe that's the version tinker was talking about, too.
Certainly a shame about the Hantek's historic bugginess issue, especially for people that bought the scope soon after it was released, but it's encouraging to me that at least they are still releasing new firmware updates that seem to contain actual fixes.
Jacob
Offline digsys
    • DIGSYS
I went through a similar evaluation a while ago and settled with the OWON SDS7102
Had to haves -  SCREEN SIZE !! Battery powered , 10MB memory
Min specs not unique -  1Gs/S , ~200+MHz (measured)
Can live without - lousy wfs/s (not good on glitches - but I have a few LeCroys for that)
Faults - nothing annoying so far, especially compared to other similar style DSOs I've used
Thanks for the opinions, digsys!  I was 95% set on the Owon when I had my first spurt of research this past April (I've had to sit on this buy for awhile).  I too am very attracted to your "had to haves".
It was very hard for me to consider the Rigol or especially the Instek given how pathetic their displays are in comparison.  Maybe that's harsh but I don't think it's unfair.  Many modern "low end" cell phones or even mp3 players have higher resolution displays these days.  Just a few years ago, however, I was using bulky (but very good) Agilent scopes at my college with small screens and floppy disk slot for screen captures so I've tried to cut the scopes with smaller screens some slack and give them a chance.  The Owon's battery option and memory are great too and far above the other scopes in this class.
Though I don't think I'll like the Owon's interface as much as the Hantek I might be able to live with it to get the battery and deeper memory.  I'm not sure if the wfs/s should be a deal breaker for me or not.  I don't have another scope to catch glitches on and I suspect it could be important to me.
I'm glad to hear you've had a good experience and haven't found any faults that annoy you so far!  Thanks a lot for adding some weight back to the Owon and making my choice harder lol.  But really thanks again I do appreciate it.
So I guess the only decision I can feel reasonably firm about so far is that I'd pick the Rigol over the Instek if those were my only two options, mostly because I think saving the money would be worth it to me.  That leaves Rigol, Hantek, and Owon as my "final three" - in no particular order at the moment.  Blast these trade-offs!
Jacob
Offline digsys
    • DIGSYS
Quote from: jneumann
... I'm not sure if the wfs/s should be a deal breaker for me or not.  I don't have another scope to catch glitches on and I suspect it could be important to me.
That's a tough one and very hard to qualify. There really is no simple way to prove that a much faster wfs/s unit won't miss glitches you're looking for.
There maybe another spec that's not as good, which reduces the effectiveness. You could spend months going over every detail, and to really prove it,
you'd HAVE to loan one of each and compare them in real life. Not going to happen easily. What makes it even worse is that, some of the much more
expensive brands have far worse issues. Search for LeCroy :-) ... mine are ALL the old school ones, with CRTs ... from the days where specs meant something.
... Blast these trade-offs!
I originally decided on the Instek at a MUCH higher price, but after wasting a few days emailing them and trying to call them over some concerns(?), I gave up.
At the time I figured I could open it up and make my own battery back-up, to solve one of my must-haves.
In the end I decided, for the price, at worst I'd have another awesome looking door stop. GOOD LUCK.
Offline tlu
Getting back to the knobs on the Hantek, I feel that it could be bit better in responsiveness especially going to the longer time base setting but it is not too bad. This is given the fact that I have not upgraded to the latest firmware yet. Currently it is:
SW 2.06.3(111122.0)
HW 1007x555583e8
Again, it is not a big of a problem as I may have made it to seem. So far no hiccups yet with the firmware. Has not froze on me for the last 3 weeks of usage now.
Offline Smokey
  • Not An Expert
Sorry it took a while to get back. The Instek does have windows zoom, it just doesn't have a split screen.
The screen size doesn't bother me really.  I don't feel like it gets in the way or anything.  Having the menu on the side is fine.  Maybe not the UI decision I would have made, but not terrible.  I wouldn't complain if it had a bigger screen, but the size is fine for what it is.  You can read it fine in the lab.
digsys, thanks for your thoughts on the wfs/s differences and for the good luck!  I'll need it haha.  I'm sure you're right about the complexity of figuring out the real effectiveness.  At 30 minutes into his review (http://youtu.be/eqcEi6ru4ZM) marmad does a glitch-finding experiment with the Owon.  That was just a single data point though and perhaps not very helpful.  It would have to be repeated a few times on each scope and averaged for a good comparison to be made.  It sure would be nice to get my hands on all three!  Wish that was possible.  Anyhow it sounds like finding a clear winner may be very difficult especially given that I can't predict what opposing features will be most important to me or most annoying not to have.  It seems like the thing I might regret most about the Owon is its slow wfs/s - but other than that I could see myself being quite happy with it.
tlu, thanks for writing back about the knobs.  It sounds like maybe that's just a symptom of the scope's difficulty handling its highest memory depths - like the waveform capture rate slowdown marmad noticed in his review (http://youtu.be/u7UgKJ8M7LY).  It sounds like one of his biggest complaints and my "deal breaker" concern - the bugginess - may be mostly a problem of the past!  Up to 3 weeks now on your new scope without a freeze up!  Thanks for that update and your SW/HW versions.  The 2/4/8 horizontal adjustments might bug me a little but it seems like the thing I might regret most at this point in the Hantek's development is its 1M memory cap (500k/channel in dual-channel!) and slowdown at "higher" memory depths.  In the end, maybe I won't find myself needing to use the full 1M memory all that often - if for instance I'm only zooming in by factors of 10 or so.  Still the memory is nearly as much worse than the Owon as the Owon is worse with wfs/s!  Other than that I could see myself being quite happy with it.
***In case I'm being an idiot, I'd like to show a bit of calculation on what the Hantek's smaller memory might mean for my example application.  For measuring a 16MHz digital clock, sampling at 500MS/s (dual-channel), I would have 31 samples per clock period (probably just fine for a square wave).  At a memory depth of 500k/channel I'd be able to store 1ms of samples which would cover 16,000 clock cycles.  Should the slower performance at max memory be an issue, I could reduce to 40k/channel.  In that case I'd be able to store 80us of samples which would cover 1,280 clock cycles.  From this I would conclude that maybe the shorter memory depth won't be much of an issue for me - or at least for this particular situation.  Feel free to yell at me if this conclusion seems fishy to anyone or I'm missing something.***
Smokey, no problem on the small delay.  I definitely appreciate any input whenever it comes.  It's interesting that the screen doesn't bother you really.  I'll bet in the end I could live with it, too, as I did with the small screens at school for 4 years.  It's a very tough call for me but I think I may need to set the Instek aside for the sake of not wavering back and forth for another month (and saving ~$70-100).  I'm sure I'd be happy with it and that it would be a good buy, but I'm getting the impression there will be no "best" decision here and I really suck at getting to a final choice in these situations.
I think the Rigol's still on the table as having the best feeling of quality, robust firmware, and warranty support - best "confidence" - at the ~$400 level.  Under consideration are saturation's comments here, comments/reviews found elsewhere, and the fact that Agilent puts their name on some of Rigol's products.  I have a good feeling about the capabilities, look, and feel of Agilent scopes so if there is a hint of that in terms of how I use it and interact with it that would be a significant factor for the Rigol.  With 80% fewer pixels than the Hantek and 85% fewer pixels than the Owon, though, I'm not sure the Rigol has enough other redeeming characteristics to push it above 3rd place.
1st: Hantek/Owon
3rd: Rigol
4th/"out" unless I get significant new info: Instek
Thanks again to all.  In one way it makes it much harder when people can say they like each of the scopes I'm considering.  At the same time though it's a great feeling to know that - whatever my decision - others were willing to speak up for the scope I picked and any of the scopes would probably serve me well (at least, as well as any sub-$500 scope could).
Jacob
Offline tlu
On a side note, you can get the Hantek DSO5062B which is the 60Mhz analog BW and hack it up to 200Mhz. CSI has the 60Mhz for $329 which is the cheapest I could fine. So if budget is a concern you can take that route. The internal guts are practically identical from the 60Mhz to the 200Mhz model according the residential hacker tinhead on this forum. Just food for thought and maybe it will help in your deciding factor.
Offline StubbornGreek
Hello jneumann, as an owner of the Owon scope I'd say that I 'mostly' enjoy working with it (aside from the obvious that has been stated in thread after thread - not to mention that I wouldn't use it to catch any intermittent issues) but if I was to purchase something in that price range again, I would be looking at something that's not been recommended on this forum yet (to my knowledge). On paper and IMHO, the Uni-T UTD2102CM wipes the floor with all the other ~$500 scopes available (although I do like the Rigol). It offers all the features you've mentioned are important to you and add 150k waveforms per second to that list. I suppose it could be rated higher (CAT II 300v) although the Owon isn't that much more impressive at 400v.
Maybe one of these will find its way to Dave's bench...
"The reward of a thing well done is to have it done"
-Ralph Waldo Emerson
Hey, thanks for the idea tlu!  I know I've mentioned I want to avoid hacking (hence why I'm considering the Rigol DS1102E instead of the DS1052E).  Still, with it being a tie at the moment and with how on the fence I am I think I will have to research the hack tonight and get fully read up on it.  How hard it is, what's required, how risky it is, if it still works with the latest scopes being produced, etc.  I haven't done that research yet so I'll hold off on asking any questions until I think I'm up to date.
Hi StubbornGreek - thanks for adding to the discussion!  I appreciate your comment on your Owon and especially the recommendation of a new scope to consider.  I don't think I've read a single word on that scope yet so I'm not sure what I'll find out.  I'm excited to look into it, though!
I will say I'm going to be mad though if it just bumps things up to a 3-way tie.  jk  :P
Jacob
Offline tlu
As for as I know when asking Tinhead the hack still works with the most recent models. It is pretty straight forward but it entails you to open the dso up to connect the usb to uart converter.
Offline saturation
    • NIST
In the end, the issue comes down to getting more features from lesser named scopes, for about the same money.
However, one consideration I rarely see when folks decide is worldwide recognized safety testing and certification.
Certification requirements also test the entire production process with factory site visits.  By insuring the factory is made to manufacture properly, safety is reassured, sampling won't catch faults between test intervals so the production process must be capable of providing a consistent product.  This was UL's standard approach and is followed by all equivalent organizations recognized in the USA as NRTL.
http://www.tuvasi.com/en/tests-and-analysis/information-about-nrtl-tests.html
AFAIK, Rigol has most of its products TUV Rhineland certified, including the lowly 1052e.
http://www.tuvdotcom.com/search/matching_product_certificates?locale=en&q=rigol
This reflects in greater consistency between what's written in the users manual and what it actually does, year after year.
I don't think Hantek or Owon have similar third party testing, or you can inquire.  I think they are CE at most and while better than none, CE is just short of useless.
« Last Edit: October 20, 2012, 03:14:26 pm by saturation »
Best Wishes,
 Saturation
In case anyone was wondering, here's a small update.
I looked into the Uni-T UTD2102CM (thanks again StubbornGreek).  Unfortunately I could hardly find any information on it - certainly not enough to be comfortable buying it.  If anyone knows where I could find a good review of it (or preferably a couple) that would be great, though.  It's a shame as its specs on paper are really good - even too good to be believable.
I still have not had a chance to read up on the Hantek hack (60MHz to 200MHz) at all.  I thought of one potential problem - the probes.  I wonder if the probes supplied with the 60MHz version would have a limited bandwidth that would reduce the usefulness of the hack.  I'll be trying to make time to read all about this soon.
I think saturation made a great point.  It seems to reaffirm the Rigol as not necessarily the best to work with or the best performer in terms of "stats", but perhaps the scope I could be most confident buying.  If I buy any of these scopes I'm going to be very apprehensive until they're actually in front of me - whereas of course with something like an Agilent X2000 I'd be merely excited.  With people willing to speak up for each scope and say they are pleased with them, it seems like the winner (for my situation) hasn't gotten any clearer.  I do appreciate everyone speaking up though to say they are overall happy with the scopes they've commented on.
It may be prudent to revisit a couple scope-independent things that no one has commented on yet:
Would 2 channels, 100 MHz bandwidth, and 1 GS/s sampling rate fit my example application?  And does my rough calculation on what the Hantek's memory would mean for me look right and make sense?  Do I seem to be on the right track in terms of not only what's popular but what would fit my needs?  Asking for input on these things probably should have been my focus in the beginning.
Thanks for any feedback from that perspective.
Offline saturation
    • NIST
Any scope you mentioned will do the work, that's probably why those issues are not mentioned.  There are pros and cons to each model.  Rigol's name began with DSO, while Hantek and Owon its just another part of their portfolio; scopes is what Rigol does foremost enough to compete with the big boys and some of that savvy rubs off in their lesser models.  If you read the threads on the Hantek and Owon, things looked rosey at first, then took a tailspin; Owon did not recover as much after 1 year of chitchat, but Hantek has after 2 years, but what else lies before them, bad or good? It seems its constantly in beta test. Lastly, tinhead maybe be solely responsible for fixing the issue, or lay heavy attention to it, not Hantek management.  Where would any buyer be without him offering detailed tech support?  If something were to come up again, there is no guarantee he'll be there to fix it, or the issue is unique to whatever version you purchased and doesn't apply to him, and so he'll have to fix it "in theory".  If you're willing to dedicate sometime to working the Hantek instead of your projects should something come up, rather than expect the scope to work as defined and transparently, Hantek is your bang for buck.
The Uni-T is discussed in the archives, just look for tinhead's comments to get the meat of it.
Best Wishes,
 Saturation
Any scope you mentioned will do the work .... Rigol's name began with DSO, while Hantek and Owon its just another part of their portfolio .... Owon did not recover as much after 1 year of chitchat, but Hantek has after 2 years, but what else lies before them, bad or good? .... If you're willing to dedicate sometime to working the Hantek instead of your projects should something come up, rather than expect the scope to work as defined and transparently, Hantek is your bang for buck.
Thanks saturation for the feedback on whether the scopes I'm looking at are in an appropriate sample rate/bandwidth/memory depth for my example application!  Would've been nice to hear 100 GHz is overkill but oh well haha.  Thanks also for again the input on the brands and the lead on the Uni-T.  I think I'll pass on considering the Uni-T.
I just came across some possibly unfortunate news on the Rigol scope:
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/rigol-ds2072-review/msg139050/#msg139050
PA4TIM seems to think some Rigol scopes, the 1102 specifically included, use display memory for measurements.   In other words, rather than looking at the actual sample points in memory to calculate duty cycle, rise time, peaks - whatever - it looks at the pixels on the screen.  With its low-res screen this practice would be especially bad, compared to IF the Hantek or Owon did this (I have no indication that they do - not trying to spread rumors).  Reminds me of Dave's "caught with their pants down" vlog haha.  (Btw, IRT that vlog if the Rigol's ADCs are more overclocked than the Hantek's that doesn't bother me too much provided measurements are still okay - basically I agree with what Dave said.)
I'd think it should be really easy to find out if this allegation is true.  One could take a single-shot recording then vary the horizontal and vertical scales and see if the measurements change.  PA4TIM seems to think the measurements do indeed change.  I'll need to look into it more as I feel I might've even come across this before in my searches.  In the meantime I'm not convinced Rigol actually does this.
Even if some Rigol scopes do use display memory for calculations, in practice it may not be much of a problem anyways.  Perhaps the error introduced would be significantly less than all the other error/tolerance built into the measurements - depending on timebase setting.  Clearly measuring the duty cycle of a pulse only 10 pixels wide would be severely impaired.  If the horizontal range was set so the same PWM period took up 100 pixels (about 1/3 of the screen) then the error would be ~1% and more tolerable.
As a side note, I'm aware that vertical measurements are handled a lot differently due to the ADC input voltage range etc so it makes sense that a 1vpp signal sampled with 10v/div will have different (and less accurate) measurement results than when sampled with 0.25v/div.  This is just as I'd expect a duty cycle measurement to change (and be much more accurate) if sampled at 100 MS/s vs 10 MS/s.  If a measurement changes on the same data when the vertical scale is changed with the scope *stopped* however, that would seem bad.
Whether or not it would be an issue in practice this still bothers me quite a bit.  I'd rather just have to think of what sample rate and volts/div I need to get good measurements - not also be tied to presenting the waveform a specific way horizontally on the display.
Can any owners of a Rigol 1052 or 1102 with recent firmware confirm or deny this behavior?  Do measurements on a single-shot recording change as you zoom in and out on it?   Since part of the purpose of this thread is to try to get up to date info on these changing scopes I think this will be helpful in general as well as helpful for me.
Thanks!
Jacob
Offline marmad
  • Country: aq
    • DaysAlive
1) I believe this is a non-issue - with most - if not all - lower-end DSOs doing it. P4ATIM's assertion that Agilent doesn't do it is belied by this quote from the Agilent 2000X/3000X User Manuals:
"Measurements and mathfunctions will be recalculated as you pan and zoom and turn channels on and off. As you zoom in and out on a signal using the horizontal scale knob and vertical volts/division knob,you affect the resolution of the display. Because measurements and math functions are performed on displayed data, you affect the resolution of functions and measurements."
2) With his image, he's comparing the noise level of a $4300 DSO to that of a $840 one.
An other test. Take a squarewave, 6MHz or so, select around 10 mS/div. Then press stop and change the timebase so the squarewave is visible in detail. About 3 to 6 periods on the screen. On the Hameg (350 MHz) and Agilent ( 10 year old 200 MHz) the squarewave was still a nice correct signal... Correct on all scopes exceot the Rigol.
3) This sounds to me like a sample length problem (i.e. if the memory depth is set correctly, this wouldn't happen).
« Last Edit: October 25, 2012, 10:45:10 pm by marmad »
Offline Herman
  • User banned.
https://www.mortoncontrols.com/blog/files/category-oscilloscopes.html
Siglent SDS1102DL/CNL/CML  and atten's oscilloscope which maybe ODM by siglent.
Offline marmad
  • Country: aq
    • DaysAlive
This supposed 150000 wfrm/s of the UTD2102CM is clearly nonsense - or the 'honest mistake' of a typo. Here at http://www.pinsonne-elektronik.de/pi1/pd125.html, they list it's capture rate at 15000 wfrm/s. Hmm... only one zero less - hardly any difference at all  ;) There is NO way I would believe what it's rate was unless verified by someone who wasn't selling it!
Add to the fact that the Uni-T looks like a piece of junk (with a terrible looking display), then why on Earth would you buy it when you can get a Rigol DS2072 (excellent build quality, beautiful display, 2GSa/s, 500uV, 50k wfrm/s, SCPI commands, etc) for $250 more??
« Last Edit: October 26, 2012, 10:57:22 am by marmad »
