Author Topic: HB100 Doppler radar motion sensor  (Read 5549 times)
Offline LukeWTopic starter
« on: June 26, 2015, 11:13:37 am »
These interesting sensors are quite cheap, about USD$5 for an interesting little device, so I thought I'd take one apart and post a pic of what's inside.
The backside of the board shows the transmit and receive antennas - a pair of patch antennas at either side of the board.
Upon removing the can, you might be surprised that (except for microstrip structures) there are only 5 components - two ICs (presumably one is an oscillator and one is a mixer), a barium titanate DRO (dielectric resonant oscillator) and one resistor and a capacitor, and three pads for 5VDC, ground and the IF output.
The nominal frequency is 10.525 GHz, and a little grubscrew built into the shield can above the DRO "puck" allows for tuning.
Some people in the X-band amateur radio community have modified these with an SMA connector, for use as a general purpose 10 GHz local oscillator: http://www.shfmicro.com/gunn.htm
Offline miguelvp
Re: HB100 Doppler radar motion sensor
« Reply #1 on: June 26, 2015, 03:29:13 pm »
That's awesome, I was impressed by Google Soli from ATAP:
http://www.tomshardware.com/news/google-atap-project-soli-jacquard,29371.html
And NVidia has been also working on it as well:
https://research.nvidia.com/publication/short-range-fmcw-monopulse-radar-hand-gesture-sensing
https://research.nvidia.com/publication/multi-sensor-system-driver%E2%80%99s-hand-gesture-recognition
Do you have a source where to get this for $5?
Edit: never mind, google found me plenty of sources :)
« Last Edit: June 26, 2015, 03:32:21 pm by miguelvp »
Offline Fraser
« Reply #2 on: June 26, 2015, 04:22:15 pm »
Thanks for this heads-up. I just bought a few at £2.75 each.
Great for 10GHz experimentation  :)
Aurora
Offline chicken
  • Rusty Coder
« Reply #3 on: October 18, 2016, 07:16:52 pm »
Here's a great article that covers some of the RF magic in this module.
http://www.allaboutcircuits.com/news/teardown-tuesday-hb100-doppler-radar-module/
The following users thanked this post: JBeale, edavid
Offline amyk
« Reply #4 on: October 19, 2016, 02:54:38 am »
bigclivedotcom looked at two motion sensing LED lamps that use something similar:
