Author Topic: Bosch GBA 12v 2.0Ah battery pack - Datasheet  (Read 1459 times)
Offline LINACboyTopic starter
« on: April 03, 2022, 09:48:28 am »
Hi everyone,
I'm looking for a datasheet for the Bosch 12V 2.0Ah 3S Li-Ion battery pack.
Specifically I'm interested in what kind of protective functions are implemented on the internal PCB, their thresholds and what exact action is taken when they are crossed:
overcurrent (peak charge / discharge value)
overvoltage
undervoltag (discharge cut off threshold)
overtemperature
On Aliexpress you can buy knockoffs of the plastic parts and PCB w/o the cells that go by the name BAT411, BAT412A, BAT413A BAT420 and similar. But I can't seem to find a circuit diagram. Has anyone ever reverse engineered the PCB of either the original or knockoff units?
I want to design some portable appliances around this pack (LED-flashlight, USB-powerbank, bar-graph charge indicator, etc.) and would like to know how much additional effort it takes in order not to fry or unnecessarily deteriorate these packs.
Offline yelkvi
  • Country: ru
Re: Bosch GBA 12v 2.0Ah battery pack - Datasheet
« Reply #1 on: April 03, 2022, 11:06:52 am »
These parameters are easily determined experimentally.
A piece of nichrome coil, a 12V light bulb and a simple multimeter.
Or do you not have the original battery?
« Reply #2 on: April 03, 2022, 12:58:24 pm »
I bought into the Bosch system, so I actually have several. But rn I'm still too cheap to risk destroying one before knowing exactly what is and isn't implemented.
For example iirc the Makita LXT 18V system has a micro controller in every pack, which monitors and counts hazardous events (overtemp, imbalance and such). If it detects too many events, it prevents you from recharging w/ an OEM-charger. They also have non-resetable fuse links.
I don't think, the Bosch system is that complex. But if someone already did all the legwork or has access to OEM-data, I'd love to benefit from that.
« Last Edit: April 03, 2022, 01:02:30 pm by LINACboy »
