The other day I decided to get one of these USB wall adapters from a reputable brand (
Leviton T5632) and take a look inside its guts before installing it.
I was glad to see the quality and the build were very reasonable for its price (US$24.00 in the local store).
Faceplate
![](https://lh4.googleusercontent.com/-wY-Y0BffSYY/VGLBFXT9OeI/AAAAAAAAAS8/tEcm0ym67WY/w919-h690-no/DSCF5996.png)
Another shot of the faceplate
![](https://lh4.googleusercontent.com/-u3BInTkgqB4/VGLBKQ4p6yI/AAAAAAAAATE/SjSepn3fxGk/w919-h690-no/DSCF5995.png)
Back cover with vents
![](https://lh5.googleusercontent.com/-p49hefj-JF8/VGLBP2-ow6I/AAAAAAAAATM/HSyRYEJBdrA/w919-h690-no/DSCF5993.png)
Faceplate removed with the ground terminal
![](https://lh3.googleusercontent.com/-8HbV6o8g6QM/VGLBVKx9I0I/AAAAAAAAATU/lu4k1sH4QpA/w919-h690-no/DSCF5992.png)
Ground terminal removed
![](https://lh4.googleusercontent.com/-w8Lh32h7eMk/VGLBgq4U0UI/AAAAAAAAATc/16dsROUjqNE/w919-h690-no/DSCF5991.png)
Removed the back cover
![](https://lh5.googleusercontent.com/-Q_dlK9OXFEo/VGLBlqh1IJI/AAAAAAAAATk/NaevtMQ083Y/w919-h690-no/DSCF5977.png)
Another angle with the view of the main board
![](https://lh5.googleusercontent.com/-RBqmEKHP82Q/VGLBxIF7WSI/AAAAAAAAATs/iuETtye6doU/w919-h690-no/DSCF5978.png)
Main board with the suppressing capacitor between primary and secondary. Shown are the beefy diodes, the suppressor capacitor, the MOSFET (FDD5N50?), the poly fuse and the tiny SOT flyback controller (UCC28700). I am not crazy about the solder joints that connect to the USB connector daughtercard (close to C2)
![](https://lh4.googleusercontent.com/-6cwkrtwK7Y0/VGLCBEQWqcI/AAAAAAAAAT0/vHYxQxNfU3Y/w919-h690-no/DSCF5979.png)
Input MOV, poly fuse and common mode choke
![](https://lh3.googleusercontent.com/-GBCFrid2rlI/VGLCFcpsj7I/AAAAAAAAAT8/swCcaawy3ao/w919-h690-no/DSCF5980.png)
Filter inductor, main cap (Capxon, but at least it is 105C), flyback transformer and DC filter caps (not sure about their brand)
![](https://lh3.googleusercontent.com/-lGsTKArUqsI/VGLC41jO2PI/AAAAAAAAAUY/fJsDyL6fdZM/w919-h690-no/DSCF5982.png)
Another view with filter caps, flyback transformer, main cap and inductor filter
![](https://lh3.googleusercontent.com/-wuRxknPTZxE/VGLC4aPAVxI/AAAAAAAAAUU/QE3N19MJcYs/w919-h690-no/DSCF5983.png)
Detail about the press wire contact
![](https://lh6.googleusercontent.com/-21d2TZoPhFs/VGLC4LYgROI/AAAAAAAAAUQ/K8pg5yfyC1E/w919-h690-no/DSCF5984.png)
Wire terminals and the PCB edge of the low-voltage USB. I did not disassembly the unit entirely, but it can be seen some SOT devices that are probably the voltage regulator.
![](https://lh3.googleusercontent.com/-lAfw0ihlX-0/VGLC7hHjg6I/AAAAAAAAAUk/hvST02IPYjw/w919-h690-no/DSCF5987.png)
Detail of the USB connector and the insulation between the AC and DC sides
![](https://lh6.googleusercontent.com/-OPUO09JjzCY/VGLC8Dr83ZI/AAAAAAAAAUs/iXq7bKhmS5U/w919-h690-no/DSCF5988.png)
Another shot at the insulation between the AC and DC sides
![](https://lh6.googleusercontent.com/-R5qcCq5cleo/VGLC82ANuvI/AAAAAAAAAUw/AThMPOb9xKE/w919-h690-no/DSCF5990.png)
