Specs:USB-A output: 4.5V-5A, 5V-4.5A, 9V-3A, 12V-2.5A
Type-C output: 5V-3A, 9V-3A, 12V-2.5A, 15V-2A, 20V-1.5A
Protocols:- USB PD 30W
- QC3, QC4 30W
- Huawei SCP/FCP 20W
Parts:-
SW3516 controller
- 3x 22uF 400V 105C Richcap RK
- 1x FCON SCA 470uF 25V
- 2x ABS210 2A rectifier (why two in paralell??)
- 2x 14N04ST FET (should be 42V 14A)
- 3.1A fuse + PTC
They claim "two intelligent chips" but I can only see the one QFN on the top.
The main chip can measure: voltage, current, and temperature (6mV, 2.5mA resolution) and control voltage in 0.2V steps.
Clearance between L and N isn't great (see BD1), but primary - secondary clearance is very good.
Measured minimum voltage: 3.6V
Measured maximum voltage: 12V so far (it should do 20.5V, but I need to investigate the library I used)
https://www.aliexpress.com/item/33010885309.html (use daves affiliate link below)
For $15 its great value.
But I still need to: get it to output 20V, and measure ripple, maximum current outputs.
