The
"chinese toy look" is actually Tektronix fault.
You remember the TDS2000 series? As Tekway started to produce their first DSOs, they copied the Tektronix
enclosure and front panel - and they did it in typical chinese way - a "bit" cheaper. Not really critical, only the holes
around BNC and test signal out could be made better. As later the Tekway DST1xxxB (Hantek DSO5xxxB) was born,
instead of redesigning a bit the knobs/fron panel to made it a bit more modern, they just reused what already there.
Finally Hantek did the rest - they started to put the sticker probably by hand (this is what i think too, when i look on my
Tekway it is placed perfectly, when i look on all Hanteks i had in last 12 months - not a single with good aligned sticker).
Maybe not a big deal, but it would probably not costs that much per unit to make them as you said "more western designed".
Interessting that Tekway is still capable to place stickers properly, they even using different material for buttons
(they a bit softer, i ilke that more than these bit hard to push Hantek buttons).
The display is indeed optimized to use the scope above your eyes and not to put on desk, that was from the beginning
and can't be changed due mechanical design (you could flip display and flip then the data by changing 2 resistors, but
mechanicaly the display will not match into enclosure). For me this was always a big plus as all my lab instruments are
above or inline with my eye level, but sure for ppl prefering to have DSO on desk not the best solution.
Firmware, yeah .. i'm sure if you would use one of the firmwares developed by Tekway before they got bought by Hantek,
you would have to wait very long time for first crash. In principle (except the first 3 fw versions right after Tekway started
the production - which is typical for new products) i never ever got issues with the older firmwares.
Sure I did found some small bugs (mostly typos), but never saw my DSO crashing.
But that was long time ago as the firmware was 100% Tekway owned. I still remember the first firmware developed
by Hantek (they said "joined team from both manufacturers, but today i know that they in principle
fired everybody and started to do own things), i found immediately more than 20 bugs!
You can imagine how funny it was to write light years long email with bug description.
Sure today many things has been fixed, many new features implemented - but as you said - you can feel that the firmware
is still under development. One of the reasons might be that the management is more focused on new features/models
than on bugfixes for exiting models. They have now BM/BMV models (with funcy videohelp, 2gb flash, 2Mpoint meomory)
- which is really unique in this class of DSO (i meand video help and integrated storage).
They have also these new handheld DSOs 100% based on DSO5xxxxB (look for DSO1000B on Hantek website). These models
have already improved firmware, e.g. with LAN support (firmware and PC software imporved), even isolated models are available.
This is again something unique in that price class, high wfrm/s, 1GSs, LAN, isolated option etc. - no wonder that the engineers
have to be focused primary on these new models.
All we can do now is to wait until they ready with new models - all these improvements are anyway DSO5000B compatible,
so finlally we will win (same for SDK).
Timebase 2:4:8 hehe, look on Tektronix MDO, they changed "standard" too.
Now when you look on Hantek, the whole DSO is a mix of dividers:
- sampling (short mem) 1-2.5-5 up to 2us/div
- sampling (short mem) 2:4:8 for 800ns/div to 20ns/div
- sampling (short mem) 1-x-x (1GSs) for 8ns/div to 2ns/div
- sampling (long mem) 1-2.5-5 up to 20us/div
- sampling (long mem) 2:4:8 from 8us/div to 2ns/div
- timebase 2:4:8
- screen 16 or 20div
now try to find common divider for these values
Interessting that when i patch timebase table to 1:2:5 it does works too, so hard to say who got confused
and why they finally decided to use 2:4:8 timebase. It sucks a bit when you work with more than one
DSO (or have 6 fingers as i do), but after some time maybe not that tragic.
What you not mentioned in your review is the not existing dual cursor and tracking cursor. Sure the two standard cursors
are there, but i would be much better to have dual and tracking cursors too. They working on that,
got just message that there is beta fw with tracking cursor, see picture.
You spoke about the fast refresh rate, yeah this is definitely nice feature, however there are two others not mentioned
in your review - the DPO-like (or like Tekway said "wave-retentive technology") and the O.T. trigger.
There is also one useless feature implemented - probe check. In principle such function should be helpful to
set the probe compensation, but it was probably implemented by an idiot (or i expect too much).
With the long memory implementation, well this is a vice versa situation to what on Owon, Tekway probably
originaly focused on maximum available wfrm/s and these DPO-like features, but screwed up a bit the long memory
implementation. When in 1M the menu is responding much slower (seems that the engineer was playing too much with Tektronix),
sure still usable (somehow) but it could be much better.
Overall nice review! Thanks for that.
