Author Topic: recommendations?: Good & low cost small, medium, large ESD mats, bags, etc.  (Read 803 times)
Offline evb149Topic starter
  • Country: aq
Hi -- I'm looking for recommendations on
good (function, durability, quality, features) but relatively low cost small / medium / large ESD mats, bags, accessories.
New or good quality industrial / commercial used / surplus acceptable for the mats.
Not necessarily "low cost" like order from aliexpress / taobao /ebay for $2US but also not like $200-$1000+ new from desco / 3m / ....
Anything worth buying on Amazon or good value & quality on digikey etc.?
small: e.g. less than 1m x 1m e.g. 14in x 14 in or whatever
medium: maybe smaller than desk / workbench size but significantly larger than the most minimal sizes.
large: covers something like 0.25 to 1.0+ times the surface of a small single person work table / work bench, more than 1m x 0.5m, maybe up to 2m x 1m or slightly more.
I'd like options for something soldering heat resistant (suitable for soldering and maybe hot air use) on / near the surface of, and options for others that may be lower cost.
It should have some standard or easily equipped by add-on a snap / terminal fixing point to attach a grounding cable of course.
Also if you have suggestions for good sources of good quality for the cost accessories like floor mats, wrist / foot straps, cables, terminals, connectors, etc. please
include those!
Metallized conductive bags: properly made ESD bags small (100mm x 100mm?)  / medium / large (motherboard size) qty 10-100 or so
Pink anti-static bags: small / medium / large, 10-100 or so.
Foam / misc material: Suitable for lining parts storage drawers, packing, not necessarily for IC DIP insertion.
Thanks in advance!
Offline Foxtrot of India
Hi evb149,
I'm looking into the same thing as well. Still tying to figure out how all this stuff works, what I actually need and how to use it correctly.
The only esd mats I could find that you can drop solder on/touch with parts being solder/reflowed are the nitrile rubber ones. AU$198.98 for a 24" x 36" (609.6mm x 914.4mm) mat.
Offline MarkF
I bought a dark blue Sierra FT series  from All-Spec five years ago.
It's 24"x48" and still looks like new.  Mine is on my home work bench and doesn't get heavy use.
It's the cat's meow!  :-+    I need to get a smaller one for my soldering bench.
I no longer solder on it because it's on my test bench and I don't want solder flakes getting into devices I'm testing.
I'm partial to the dark-blue (more of a royal blue in person) but there are other colors.
All-Spec has a full line of ESD products.  (Not exactly cheap.)
