Hi -- I'm looking for recommendations on
good (function, durability, quality, features) but relatively low cost small / medium / large ESD mats, bags, accessories.
New or good quality industrial / commercial used / surplus acceptable for the mats.
Not necessarily "low cost" like order from aliexpress / taobao /ebay for $2US but also not like $200-$1000+ new from desco / 3m / ....
Anything worth buying on Amazon or good value & quality on digikey etc.?
small: e.g. less than 1m x 1m e.g. 14in x 14 in or whatever
medium: maybe smaller than desk / workbench size but significantly larger than the most minimal sizes.
large: covers something like 0.25 to 1.0+ times the surface of a small single person work table / work bench, more than 1m x 0.5m, maybe up to 2m x 1m or slightly more.
I'd like options for something soldering heat resistant (suitable for soldering and maybe hot air use) on / near the surface of, and options for others that may be lower cost.
It should have some standard or easily equipped by add-on a snap / terminal fixing point to attach a grounding cable of course.
Also if you have suggestions for good sources of good quality for the cost accessories like floor mats, wrist / foot straps, cables, terminals, connectors, etc. please
include those!
Metallized conductive bags: properly made ESD bags small (100mm x 100mm?) / medium / large (motherboard size) qty 10-100 or so
Pink anti-static bags: small / medium / large, 10-100 or so.
Foam / misc material: Suitable for lining parts storage drawers, packing, not necessarily for IC DIP insertion.
Thanks in advance!
