You will need to alter the Iron holder bracket to fit a nut at the bottom. Like I said I used an old drip tip to secure the iron. I could send you the .stl file if you like. Can I do it by Pm?
For a complete tip information please see this article: http://www.ebay.co.uk/itm/Original-Replacement-Solder-Tip-For-TS100-Digital-LCD-Soldering-Iron-/182720381090There you can find all avaliable tips, their size and modelsI recomend the D24 tip for most of the worksActualy i found that heat times are bigger than actually is.My 24V 5A (120W) heat up to 350ºc in just 6s
I'm wondering how the TS100 irons are working out for everyone. Are the tips good quality and do they last? Has anyone compared the TS100 performance and tip quality to those cheap T12 stations that are for sale all over the place?
