Author Topic: DC 2 DC problem  (Read 6502 times)
Offline jarleicemanTopic starter
DC 2 DC problem
« on: November 30, 2013, 06:38:43 pm »
Hello
I'm a man from the Cold North...Norway, and I have a question about DC2DC... :-DD :
I shall use this in a set of active headphones..and there are a 1,5v AAA batery here, but the voltage is to low...I have to have at least 2v for it...(not more than 3,5v..)
and the current is less than 100 mA, so I wonder if you have a solution for my project:
with a small capasators diodes and resistor (at easy at is can be...) I dont want to use active compenents (like Op-Amps etc...)
mabe a dobler of the voltage how do I do it....(I see I can use a DC.DC boost converter), but I want too make it cheap and with as less components as posible.... :-// :-//
senserly
jarleiceman
Offline vk6zgo
Re: DC 2 DC problem
« Reply #1 on: December 01, 2013, 12:33:51 am »
Two AAA batteries in series gives you 3 volts.
Offline Skimask
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline IanB
Re: DC 2 DC problem
« Reply #3 on: December 01, 2013, 01:28:54 am »
Hmm...
...oh yes! What an idea!
Ask yourself, can you make a circuit with capacitors, diodes, resistors (and yes, transistors), that fits in a space smaller than an AAA battery?  Will it also be cheaper than an AAA battery? Fewer components than one AAA battery? More efficient than one AAA battery?
By Jove, I think I see the answer! The cheapest, simplest, most efficient voltage doubler is a second AAA battery! Two AAA batteries in series gives you exactly what you are looking for!
Offline peter.mitchell
Re: DC 2 DC problem
« Reply #4 on: December 01, 2013, 03:35:09 am »
A round of applause for this man!
How do you know not more than 3.5 just curious? If allowed more than 3.5, eg, 4.2, you could use a lithium 10440 cell.
Offline vk6zgo
Re: DC 2 DC problem
« Reply #5 on: December 01, 2013, 06:04:12 am »
I kept reading & re-reading it to see if I'd missed something pertinent,but it seems just what it says---he wants to get around 3v with AAAs.
Hence my suggestion of two in series! ;D
I've noticed a lot of people want to go for the most complex way of doing things,regardless of whether there is any advantage In doing so.
Re: DC 2 DC problem
« Reply #6 on: December 01, 2013, 02:25:58 pm »
Of course I'v think about 2 AAA...and get 3v...but there isnt PLACE..... O0
jarleiceman
Offline mariush
Re: DC 2 DC problem
« Reply #7 on: December 01, 2013, 03:38:21 pm »
I already gave you a solution, with that LT1037 ... with the SOIC version and smd inductor, diode and capacitors, you can fit in half the space of an aaa battery and it will basically be a few mm tall.
Here's the post: https://www.eevblog.com/forum/beginners/dc2dc-1-5v-to-2v/msg339940/#msg339940
Here's my project : a 9v battery replacement ... The LT1037 takes 1v-2.7v from the supercapacitor and makes ~5.7v for a multimeter with 9v battery holder (the meter says battery low at 5.5v).
You don't need the trimpot at the top, you can just use a fixed resistor to get your voltage, i wanted to be able to adjust it. You can also move to everything surface mount and basically get it to use much less space.  I went with prototyping board and all through hole :
« Last Edit: December 01, 2013, 03:47:28 pm by mariush »
Re: DC 2 DC problem
« Reply #8 on: December 01, 2013, 05:23:59 pm »
Yes Mariush, I'm goinig for the LT1037...thank you for the serios and good answer, just what I was loocking for :-DD
Offline TheBorg
  • Hoping to start an EE degree soon...
Re: DC 2 DC problem
« Reply #9 on: December 01, 2013, 09:51:18 pm »
What type of headphones is it? I'm sure if they left place for a replaceable battery they would've made it easy enough to find an actual replacement.
Youtube Channel - Assimilated Circuits
We are Borg. You will be assimilated. Resistance is futile.
Offline vk6zgo
Re: DC 2 DC problem
« Reply #10 on: December 01, 2013, 10:59:28 pm »
Well,had we known you had two threads running,it might have helped.
You also appeared to be have limited knowledge.
I'm still very dubious-----the volume of an AAA is very small.& really small inductors are not very efficient.
You gave the impression that you were quite restricted in what you could easily obtain,but if you can get the LT1037 & stuff like that,you could also use Skimask's suggestion with one or two series diodes to reduce the voltage to your requirement.
Re: DC 2 DC problem
« Reply #11 on: December 02, 2013, 04:39:55 pm »
Thanks guys
You say: "You also appeared to be have limited knowledge"...
I'not...my English isnt very good..but I have a very good eduqation in data- & Electronics, and then I have been a high school teacher on  in Data- & elecronics for about 10 years,  but then I had a strooke (brain) and i'm working hard too come back...but I know my way around electronic, but as I sayed it been some years seence I practice.....and yes the simplest soloution is Skimask's  suggestion with one or two series diodes to reduce the voltage...And its BOSE Comfort Quite 15 headset...they doesnt work With only 1 AA (1,5v) any moore...but if I increase the voltage to 2.3---3..V it kick in and work, and the LED  (Power on) lights up....?? ;)   :-BROKE
jarleiceman
Offline jabramo
Re: DC 2 DC problem
« Reply #12 on: December 02, 2013, 10:42:26 pm »
Have you tried hunting down the root cause in the headphones circuitry?
If you want to go with a 2 AAA maybe you could consider something like this http://thumbs1.ebaystatic.com/d/l225/m/mIxtcSIBL1P2cvP50B50Dtw.jpg
Just attach that to the headband and solder the wire's to the terminals of the battery holder.
EDIT: Here is the battery terminal for the headphones
« Last Edit: December 02, 2013, 11:14:19 pm by jabramo »
Re: DC 2 DC problem
« Reply #13 on: December 03, 2013, 03:08:21 pm »
Thanks 2 U all
It was actually Place for a AAA inside (dont know if it effects the sound...)and I serial conected them, a litle super-glue...worked like a charme.... :-+ :-+
but I give my left arm for the schematics for these.....
Offline djococaud
  • General rule : Simpler is Better
    • Djo Labs
Re: DC 2 DC problem
« Reply #14 on: December 04, 2013, 07:04:23 am »
What about a small joule thief Psu ?
I've played with these and I know they can be very small...
I've used it to power leds goggles with an old "dead" AAA battery, very tiny and works like a charm ! :-+
If you want a clean output, just add a capacitor on the output... ^-^
Offline TheBorg
Re: DC 2 DC problem
« Reply #15 on: December 04, 2013, 07:07:56 am »
Thanks 2 U all
Can't do much worse than this
