After hearing good things about the Quick 957D, I decided to pick up this analog version Quick 957 hot air rework station during Black Friday for around $36.
Here's what it looks like. Comes with three nozzles and correctly installed mains wiring.
Complaint #1: my hose is kinky right off the bat.
Like other cheapo rework stations: the handpiece holder can be switched to the left side, the protruding lip will catch on the rim of the handpiece to prevent it from sliding off, and there are magnets inside which will actuate a switch/sensor in the handpiece for the auto-off function.
Fit and finish is about as good as that of a free after rebate PC power supply.
Well... it looks like I got what I paid for.
(Aoyue) 857A... I don't see a micro anywhere, so I guess the LM324 is driving the whole operation?
It does actually work ok. Temperature control was verified with my UT71B, and I was able to desolder a few parts off of this PCI modem with little trouble.
And now a question for you guys: should I keep this unit, or should I return it and grab an 858D clone instead? For what I paid, I wouldn't consider this a bargain, and the kinks in the air hose interfere with airflow unless I hold it at specific angles. Are there any advantages to having the blower inside the base as opposed to the handpiece?
Thanks for looking!
