Hey Guys
I had a dead motherboard laying around which I was about to throw away.
So I thought it would be interesting to take a look inside the CPU itself.
I heated the puppy up with a hot-air gun, and lifted the CPU of the MB. And carefully broke of the fanout board from the core itself while applying heat with a blowtorch.
I ground the CPU on 1800c sandpaper with a glass plate underneath for a short time, to get a nice surface as of pic 1.
I discovered that the copper interconnect layers, and dye itself was so ridiculously thin that it was impossible to control the grinding this way (pic 2 and 3).
So I took a tiny peace of sandpaper, and bend it to get a sharp point which I could use to grind down more where it needed to. I finally, at the very last layer, managed to get (almost) the whole dye visible.
It looks very fascinating if you haven't seen the guts of a CPU before.
(The pictures are not the best, but bear with me, it's not easy to focus on such a thing, while getting the right angle of both (a very bright!) light, and camera at the same time
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
WHILE KEEPING THE CORRECT TONGUE ANGLE !)
Hope someone find this interesting, at least I had fun with it
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
- Mads
