Author Topic: Quality Breadboards  (Read 12825 times)
Offline ahnuts72Topic starter
Quality Breadboards
« on: October 16, 2013, 04:28:28 pm »
A recent conversation I was having with c4757p reminded me how crappy my no-name bread board was.
What are some good breadboard manufactures you would recommend to replace mine.
Something in the 1500 to 2000 tie-point range
Sent from my Milestone X using Tapatalk 2
« Last Edit: October 16, 2013, 04:33:24 pm by ahnuts72 »
Offline edavid
Re: Quality Breadboards
« Reply #2 on: October 16, 2013, 04:35:18 pm »
Thanks that'll teach me not to use the search feature.:-[
Offline Alexei.Polkhanov
« Reply #3 on: October 16, 2013, 10:00:25 pm »
I ordered few on Ebay, got one from local electronics supply store and had to throw them all out soon after. Only this ones from DigiKey I found usable but relatively cheap: http://www.digikey.ca/product-detail/en/TW-E40-1020/438-1045-ND/643111. They have self-adhesive tape on bottom and slide into on another to form bigger board as most others do.
Offline c4757p
  • adieu
« Reply #4 on: October 16, 2013, 10:03:19 pm »
What a coincidence. I just checked which ones we have in our school lab kits, because they're pretty decent. Those ones. I recommend them too :-+
Offline BurtyB
    • 8086 Consultancy
« Reply #5 on: October 17, 2013, 12:43:47 am »
I'd still like to see breadboards for wider ICs and modules (either wider spacing or more than 5 holes in the row).
So far the closest I've seen are some pictures of an "antique" looking breadboard with a wider centre - I know I could stick 2 breadboards down to give a wider spacing but it's not the same.
Offline staxquad
  • Eye Candy
« Reply #6 on: October 17, 2013, 01:44:32 am »
using Alexei's info, from the same company at DigiKey
$38.52US from Digi-Key.com, $43.80CAD from Digi-Key.ca
TW-E41-1060
Number of Terminal Strips   3
Number of Distribution Buses   4
Number of Tie Points (Total)   2390
Number of 5-Tie Point Terminals   378
Number of Binding Posts   4
this one is $50 from Global Specialties (other thread):
I use a cheap one from China, $15 (shipped).  Don't know if I'd ever spend $45 or $50 (or $116 for the 3M) on a breadboard.
« Last Edit: October 17, 2013, 03:09:30 am by staxquad »
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
Offline c4757p
  • adieu
« Reply #7 on: October 17, 2013, 01:50:01 am »
Quotes deleted text
Commercial advertising should be limited to the Buy/Sell/Wanted section, and nowhere else.
Dude... do you mind? >:(
« Last Edit: October 17, 2013, 03:52:13 am by GeoffS »
Offline grenert
« Reply #8 on: October 17, 2013, 02:45:24 am »
Like a number of posters in the other thread mentioned by edavid, I really like my 3M breadboard.
http://www.digikey.com/product-detail/en/922327/922327-ND/180291
I've also had good luck with boards from Wisher (not quite as solid as the 3M, but very nice), sold branded for Jameco and Radio Shack (not sure if all of RS breadboards are from Wisher, but at least this one is).
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?search_type=jamecoall&catalogId=10001&freeText=20812&langId=-1&productId=20812&storeId=10001&ddkey=http:StoreCatalogDrillDownView
http://www.radioshack.com/product/index.jsp?productId=2882885&filterName=Type&filterValue=Breadboards
« Reply #9 on: October 17, 2013, 02:50:27 am »
Thanks guys I think I have narrowed it down to 3M or global specialties.
As for components I just got it a couple weeks ago and only use 1/4 watt resistors and ceramic caps and 555 type ic's so no way near wore out.
If you see one on eBay with a green fiberglass base and spring clamps to connect power RUN don't walk away from it.
Sent from my Nook HD
« Last Edit: October 17, 2013, 02:54:17 am by ahnuts72 »
Offline ijchan223
« Reply #10 on: October 17, 2013, 03:00:47 am »
Elenco boards are pretty good, have about 20 of them at the school lab that i manage, haven't seen any real issues with connections yet. Only a couple burn marks and i tested them it seems to work fine so i am going to assume it is from user- error
we also have a couple of global specialties boards that are about 15 years old that seems to be holding up well
Offline echen1024
  • 15 yo Future EE
« Reply #11 on: October 17, 2013, 04:11:10 am »
I use an Elenco in my lab...
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline Flump
« Reply #12 on: October 17, 2013, 09:56:02 am »
http://www.kandh.com.tw/products_2.php?prod=67
i have the ad14 can take pics of it if you like
very nice quality, couldnt be happier with it
Offline mianchen
« Reply #13 on: October 17, 2013, 10:48:06 am »
I've got an AD12, bought from Maplin - about the only thing worth buying from Maplin (an offline overpriced eBay ^-^ in the UK)
But I like my small 3M one more.
« Reply #14 on: October 17, 2013, 01:51:17 pm »
The KandH look really good as well I'll add it to the list and I like the layout the vertical rows at the bottom. I don't have a problem spending some money this time so long as it will last.
I can guarantee I won't get cheap made this time to save a few bucks talk about headaches trying to get my circuits to work.
« Last Edit: October 17, 2013, 01:53:59 pm by ahnuts72 »
Offline mianchen
« Reply #15 on: October 17, 2013, 06:29:39 pm »
Just noticed Dave uses K&H :)
Offline staxquad
  • Eye Candy
« Reply #16 on: October 18, 2013, 08:02:15 pm »
There should be a rule you have to check in your Credit Card before you enter the  EEV Blog forum  |O.
But what could I do, I felt inadequate :-//
And all this reviewing of the strata of better boards, I had to feed my upgraditis
Seems like the 3M had the best reviews, so I bought 2 of them  >:D
But I still managed to remain a cheapskate and stay true to "Don't know if I'd ever spend $45 or $50 (or $116 for the 3M) on a breadboard.", I purchased new old stock  :phew:
The small one is similar to mianchen's small 3M breadboard, 840 tie points ($10 + $5.95 shipping US) and I also got a slightly larger 1824 tie points 3M breadboard ($22 + $5.95 shipping US)...  they are $50 and $80 at DigiKey
And I like what it says on the package "Sturdy Metal Base Plate - to help minimize noise and voltage spikes in today's high speed circuits".    Why would K&H use ABS?
http://www.ebay.com/sch/m.html?_odkw=&item=151144305575&_osacat=0&ssPageName=STRK%3AMEWNX%3AIT&_ssn=qualitycablesource&_trksid=p2046732.m570.l1313.TR2.TRC1.A0.Xbreadboards&_nkw=breadboards&_sacat=0&_from=R40
still 8 left, small to big selection
« Last Edit: October 21, 2013, 10:02:26 pm by staxquad »
Offline madshaman
  • ego trans insani
Quality Breadboards
« Reply #17 on: October 18, 2013, 08:05:39 pm »
Have a number of the 3M boards, they've done me quite well.
To be responsible, but never to let fear stop the imagination.
