Hello, I'm new here. I found an old Honeywell Model 356358-3 continuous balance unit. I am looking for the specs or schematic for this unit. I plan on using mainly the Power Transformer for a project, but do not know the specs. I know that it uses four tubes: two 12ax7 and 12au7, which I can assume that the filament is either 6.3v or 12.6v, and the metal can capacitor has three 10uf 450v so I am assuming that the HV is around 300-400v, but I am unsure. Can anyone point me in the right direction? I cannot find anything on this on the web. Thanks
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
