Author Topic: 110 V 60 Hz to 220 V 50 Hz - of the shelf  (Read 1406 times)
Offline jancumpsTopic starter
  • New Low
« on: June 08, 2018, 04:47:04 pm »
I'm looking for suggestions for a commercial America to Europe converter. For household, not Lab.
It should convert 110 V 60 Hz to 220/240, 50 Hz. It needs to deliver around 20 Watt.
The shape of the output signal isn't very critical. It has to be sinosodialish, but doesn't have to win a beauty contest.
It has to drive a synchronous AC motor so frequency stability at the output side is more important.
Drift over time is not critical, just not a lot of short term frequency drift because the receiving side is a turntable.
I would appreciate if you know of such a product.
Offline Ice-Tea
    • Freelance Hardware Engineer
Re: 110 V 60 Hz to 220 V 50 Hz - of the shelf
« Reply #1 on: June 08, 2018, 04:49:41 pm »
You could, off course, tie a 12V converter to a car inverter and call it quits. Probably what's going on inside an all-in-one anyways...
The following users thanked this post: jancumps
  • New Low
« Reply #2 on: June 08, 2018, 04:54:23 pm »
I've seen a few ebay offers that do that. It is an option that I keep open.
Offline edpalmer42
« Reply #3 on: June 08, 2018, 05:18:59 pm »
Some higher-end UPSs (i.e. Liebert GXT2) have the ability to output a different frequency than the input.  Voltage conversion would have to be done with an external transformer.  But unless you can find a UPS really cheap, the car inverter would probably be a more cost-effective solution.
Offline schmitt trigger
  • Country: mx
« Reply #4 on: June 08, 2018, 05:57:15 pm »
Out of the box idea;  8)
The power requirements are low, so I am tempted to suggest a class-D audio amplifier, feeding a step up transformer.
The frequency stability and the waveform distortion would be dependent on the source feeding the input.
  • New Low
« Reply #5 on: June 08, 2018, 08:26:30 pm »
110 V ?
Online NiHaoMike
    • Facebook Page
« Reply #6 on: June 09, 2018, 03:37:47 pm »
A VFD would work if you can find one cheap enough.
