Similar to another post but different.
All of the air dispensers (the cylinder with hose) use these green plastic connectors like the attached image, however the connector on my dispenser unit uses the push-fit style connector. It does work, but in my experience, the push fit connectors don't last.
So I was wondering if anyone knows what kind of connector this is, and whether I can get a panel mount socket for the dispenser unit.
I've googled around and only manage to find it on the non-clone dispenser units, but it hasn't helped me identify it.
If I can't get the socket, then I'll look at replacing both ends with a different quick connect plug and socket.
