I am building a DC Electronic Load. I would like to use a pigtail, to wire the MOSFETs. That is to say, I want to be able to set all of the MOSFETs on the heat sink, secure them, with the HS bar clamp and just plug in the MOSFETs. This connector would have the wires come out of it, to solder to their supplies.
In the past, I connected all the common MOSFET pin, with 12 gauge wire. This made a fragile framework assembly, that was a pain to build.
I am having trouble finding this pigtail. Maybe one is not manufactured. Or, maybe I do not know the right terms, by which to search. "TO-220 pigtail" and "TO-220 wire connector" did not produce any relevant results.
Any help finding this item would be appreciated.
