Hey all,
I’m looking for the most reliable, milspec, aerospace, NASA approved way to join 3-5 stranded 24 AWG wires together where there’s likely to be a lot of vibration. I understand that solder has a nasty habit of wicking up the strands, and the point at which the unwetted wire meets the wetted wire can be brittle and unreliable. I also understand that solder isn’t a great mechanical joint. I’m therefore looking for a good crimp I can use to splice several wires together. Any recommendations? Also, if I’m wrong about solder joint reliability, I’d be interested too!
Thanks!
