Hello,
Does anyone here owns a Aixun T320 soldering station and could measure the voltage between Tip and Ground please.
Just want to buy one but saw a video where the former model - T3A has about 1V from Tip to ground (ground from same wall socket). Even drives a speaker / buzzer that way between GND & Tip.
Would be nice to know if it’s the same with T320 or if it got solved.
Otherwise I would buy a Trafo station but the T420 is a bit pricey as 2nd station only that I doesn’t need to change hand pieces that often at my Pace ST-115. Maybe a Aifen or some used one then.
