Author Topic: Lab overhaul  (Read 14556 times)
Offline hacklordsniperTopic starter
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: Lab overhaul
« Reply #25 on: December 02, 2011, 06:11:01 pm »
You should install power the outlets as fixtures in/on the wall behind the bench.
I had that system before but was looking for an idea to get rid of all.
Oh, the joy of sending various electronics to silicon heaven
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Lab overhaul
« Reply #26 on: December 02, 2011, 06:15:43 pm »
Awesome! I am jealous.
I stuck mine to the underside of a shelf in my mini Lab (built inside a shelving unit with a fold down bench top).  the right hand unit is 120V the left box is 240V for the 240V items I have.  Sorry for the poor picture quality, I had to brighten the images so you could see what was going on back there in the dark.  They are stuck up there with the 3M Command strip adhesive strips.
If they are not available you can use the heavy duty foam mounting tapes.
Offline sonicj
  • updata successed!
Re: Lab overhaul
« Reply #27 on: December 02, 2011, 06:43:57 pm »
stubby IEC cords
Offline Time
Re: Lab overhaul
« Reply #28 on: December 02, 2011, 07:09:48 pm »
so much wood...
-Time
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Lab overhaul
« Reply #29 on: December 02, 2011, 08:01:25 pm »
  • Country: hr
    • HackLordSniper
Re: Lab overhaul
« Reply #30 on: December 02, 2011, 11:46:06 pm »
In the end i mounted them to wall, it was the quickest solution.
And what is bad in wood?
