I guess it's doomed already because you'all made up your minds, run for the hills! ![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
It ultimately comes down to how you value your time.
If you have endless time that in your view costs you nothing, then fine, use a DIY PnP machine, you can make it work.
It might take 5 passes of your board, tweak it after every 10th part, fiddle with the tape, change the reels, set it up and trial it etc.
But ultimately you will never ever be more efficient than a professional level machine and someone who works cheap who's full time job it is to use and maintain these machines. Or simply placing the parts yourself by hand.
Remember, the only time the PnP machine saves you is hand placing the parts. You still have to manually stencil your board, and then manually reflow it.
So it comes down to a matter of trading off time to set up a hand placing system or set up the PnP machine.
And then trading off hand placing time to watching the PnP machine and fixing the inevitable things that go wrong. Even the pro ones aren't really set and forget.
There are certainly some instances were a home made PnP machine could be very useful. Say for example you had a board with 1 hundred 0805 resistor and caps and one big chip. Well the PnP could be useful for the huge number of parts, and the one awkward chip could be placed by hand.
But if you have a complex board with 30 different parts of all different physical sorts, well, good luck with that, you are probably wasting your time even trying to get it working.
It's just like making your own PCB's, there is a very narrow window of justification when you can get a professional PCB made for $5/sqin
