What exactly did you need to do?
Well, it took good half hour for me to figure out how it all works. It was not in proper position, and was not pulling mirror correctly, so it could not return in
up position after lock release.
Standard AF-ON button does not work (no reaction). AF-ON on portrait side works fine.Done, stupid me, it was a9 menu setting, button was select to wrong mode. It works well.
Clean image sensor. Done, now nice and clean, enough to not see anything with f/16.
Autofocus need adjustment, with 50/1.4D it gets too close. Likely AF unit aligment or adjustment.Done via adjusting AF finetune +3 and turning two AF module screws #295 4.5 turns counterclockwise.
It's exactly the case when need to read service manual before doing assembly. I skipped that part, and just assembled everything for "seems correct" aproach
But AF module with its optical block have two adjustment screws #295 with very fine thread, so it adjusts distance between AF module and image plane.
Now mine 50/1.4, Sigma 150/2.8 macro and Nikkor 28-70/2.8 are spot on for focus.
By time when I got all assembled, it was already 5.00am, so I put camera on tripod near my apartment window and let it shoot timelapse, 400 photos, interval 5 minutes between each.
4K timelapse test with fixed D3.
That's one of reasons why I bought this camera, so I could leave it shooting timelapse for days, while still being able to take usual photos with my primary cam.
Maybe timelapse for my homelab during 1 month will be next?
Still left minor fixes (soak rubber pads in acetone to get them proper size, glue them to camera body) and get copycat battery and charger from ebay, so I could use it without need of permanent 110V AC jack.
But that's it for now, not going to dismantle camera again, unless reason for.
P.S. only 6 extra screws which I don't know where to put
