Author Topic: Any one use Lecroy waveform generator?  (Read 5795 times)
Offline ColinTopic starter
« on: May 14, 2012, 09:43:32 am »
a little weird to see them on Lecroy website, too fast
Anyone use it now?
http://www.lecroy.com/wavestation/?mid=1043
WaveStation 2012
10 MHz, 2ch 14bit 125MS/s 3.5" Color Display Function/Arbitrary Waveform Generator
WaveStation 2022
25 MHz, 2ch 14bit 125MS/s 3.5" Color Display Function/Arbitrary Waveform Generator
WaveStation 2052
50 MHz, 2ch 14bit 125MS/s 3.5" Color Display Function/Arbitrary Waveform Generator
never too late to learn
Online nctnico
Re: Any one use Lecroy waveform generator?
« Reply #1 on: May 14, 2012, 09:50:12 am »
You do know the generators can also be bought under the brand Siglent and some other brands?
http://www.ebay.com/itm/Siglent-SDG1005-Signal-Generator-Better-DG1022-/330730916381
Offline Bored@Work
« Reply #2 on: May 14, 2012, 12:28:53 pm »
Oh dear, LeCroy again selling Atten/Siglent junk under their own brand. Someone at LeCroy really wants to devalue the brand.
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: May 14, 2012, 06:19:53 pm »
 ;D
« Reply #4 on: May 15, 2012, 12:41:43 am »
Agilent has a better choice, they choose Rigol at first
Offline Bored@Work
« Reply #5 on: May 15, 2012, 06:12:56 am »
And they did the right thing, using the rebranded Rigols to buy themselves time to prepare their own offerings.  Instead of just sitting there and twiddling thumbs Agilent developed the astonishing  InifiniiVision 2000X and 3000X series.
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: May 15, 2012, 09:25:08 am »
Unlike some company's name which rhymes with troy and begins with le
which for the low-end( not exactly low end the price,eh? ) which does mad brand engineering first rebranding a popular highly hacked scope and then a not too bad AWG ... for a massive price that comes with a black-only option.
Offline nixxon
  • Country: no
« Reply #7 on: May 31, 2012, 09:59:05 am »
I decided to buy Siglent SDG1020, because:
Siglent have way better specs than the Atten version. (Attens even have no USB as standard)
Siglent is better priced than Aktacom, MyWave and LeCroy.
The price for the SDG1020 was just low enough (US$ 335 incl. EMS shipping) that I didn't go for the more famous Rigol DG1022 (with slightly lower specs).
I find it hard to believe that Atten (Shenzhen Atten Electronics Co. Ltd.) is the manufacturer behind the (seemingly) way superior Siglent AWG's (SDG1000 series).
nixxon
Links to the lookalikes:
http://www.attenelectronics.com/productBody.aspx?id=147&bid=28&sid=101
http://www.tmatlantic.com/e-store/index.php?ELEMENT_ID=7188
http://www.szmywave.com/categoryen.php?id=33&lang=en
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #8 on: May 31, 2012, 02:46:57 pm »
Quote from: BAW
yes even the mains switch mechanism is novel!
Offline T4P
  • Country: sg
    • T4P
« Reply #9 on: May 31, 2012, 03:39:24 pm »
Quote from: BAW
... "You could fly to the moon on that!"
