Author Topic: Vintage Weller stations - opinions / tests / tips  (Read 1650 times)
Offline mt777Topic starter
« on: June 16, 2024, 07:14:08 pm »
I like vintage computing and want use tools for my hobbyist purposes.
Recently acquired a few old Weller machines but I need help to ressurect them to working state. Even with manuals, some configs are confused to me.
1. WELLER DS701EC
Double station with desoldering gun (DS21). Seems works as expected after replacing filters and glass. I wait for new tips to do tests.
Drawback: 50W only
2290637-0 2290629-1 2290633-2
2. WELLER WDD80V
Desoldering station without vacuum. Gun DS80 (not DSX) so tips are the same like for older version.
More power: 80W. Handle is very hot (uncomfortable)
Problems/questions:
1) What I need as external air source? with reasonable size. I couldn't find photos on web of full set. Every selling unit is without providing air solution... Temporarily I connected as air pressure source to DS701EC
2) Comparing to DS21 gun: diameter hole is much smaller than DS21 (see attachments). So vacuum is worse or maybe it is compensated by stronger external air source?
3) What is difference between DSX80? Are new tips style better (DX serie) than older DS ?
2290641-3 2290645-4 2290649-5 2290677-6
3. WELLER AG701
Hot air station. There is reaction for pedal.
I have 2 different guns but don't understand them well.
Problems/questions:
1) One gun is with DIN ending. So it means no air but what is purpose of it?
2) The second gun is for air source? but don't understand innerside 3pin cable connector?
2290653-7 2290657-8 2290661-9
Also own opinions of these machines are welcome.
« Last Edit: June 16, 2024, 07:25:19 pm by mt777 »
Re: Vintage Weller stations - opinions / tests / tips
« Reply #1 on: July 18, 2024, 02:23:00 pm »
bump
Offline Kjelt
« Reply #2 on: July 18, 2024, 08:33:11 pm »
2. WELLER WDD80V
Problems/questions:
What do you mean exactly?
As many Weller desoldering stations they have a venturi element so you need to provide 4 to 8 bar of pneumatic air preferably filtered at 5 um but 40um will do.
I always use the middle so 6 bar which works fine for me.
So you need a compressor , a small low noise one with a pressure regulator and filter, usually they have an euro fast coupling outlet (check) so you also need a euro plug with an output to the pneumatic hose the Weller accepts. On the blue plastick knob on the weller it says 6 or 8 which is the outer diameter of the hose required.
You can buy them anywhere just an example
« Last Edit: July 18, 2024, 08:38:08 pm by Kjelt »
