Author Topic: Pace ADS200 soldering station  (Read 454561 times)
Offline Shock
Re: Pace ADS200 soldering station
« Reply #1875 on: April 29, 2024, 08:20:24 am »
There is a true two-channel AT420 hot tweezer with some 160 Watts. PACE has no such hot tweezer.
According to JBC they have no such hot tweezer either.
160W exceeds the DI, DDE and DME rated channel power. The DI is only 130W total, the DDE (a 2 channel station) rated 190W total, based on that alone I would not be claiming "true two-channel" or "160W" anything.
Offline tooki
« Reply #1876 on: April 29, 2024, 10:56:17 am »
Soldering station manufacturers do seem to love playing games with power ratings, don’t they?
The following users thanked this post: pope
Offline thm_w
  • Non-expert
« Reply #1877 on: April 30, 2024, 12:10:13 am »
Its a small mistake by Hydrawerk:
- AT420/HT420 are rated 80W max per cartridge
- DDE control unit is rated 150W per tool
So peak power draw would be 150W instead of 160W. Thermocouple feedback is per cartridge as mentioned.
But yes the "power spec wars" tend to confuse the masses. Which is why people like Project Farm and SDG are so valuable IMO.
Offline 2N3055
  • Country: hr
« Reply #1878 on: April 30, 2024, 07:24:57 am »
Funny thing is that on their web site https://www.jbctools.com/ they don't even specify power for cartridges.... Can you please point me to a place/document where JBC even specifies the cartridge power. They do for stations but I can't seem to find specification for tips...
Offline thm_w
  • Non-expert
« Reply #1879 on: April 30, 2024, 08:52:23 pm »
Tips aren't specified no. I just assume they all use the power available, software limited by the handle or station value, as the cold tip resistance is super low (2.4 to 2.5 ohm for 245/420).
ADS200 cold tip resistance is 4-4.2 ohm. About 135W at 24Vdc.
AT420: https://www.jbctools.com/pdf/manual-at420-adjustable-tweezers-0030510_ID-229722.pdf
DDE: https://www.jbctools.com/pdf/manual-dde-control-unit-0027023_ID-222436.pdf
HT470: 250W per cartridge, but thats just obscene: https://www.jbctools.com/pdf/manual-ht470-thermal-tweezers-0029612_ID-229658.pdf
Offline Shock
« Reply #1880 on: May 01, 2024, 07:26:53 am »
If I recall correctly the Pace ADS200 supplies roughly 30V DC to the heater not 24V.
Offline tooki
« Reply #1881 on: May 01, 2024, 10:26:46 am »
Not quite. Looking at the schematic, it powers the heater with full-wave rectified*, but unsmoothed voltage from the transformer, so the peak voltage will be around 30V, but the RMS voltage is 24V, the same as the unrectified 24V AC. They then do zero-crossing detection to only switch at 0V.
The same rectified AC then goes through a diode and from that point is smoothed with a capacitor, creating a 30V DC rail which then powers the 7805 to generate the +5V rail for all the control circuits.
*Through a full-bridge MOSFET rectifier, so no diode drop losses! :)
Offline bdunham7
« Reply #1882 on: May 01, 2024, 12:24:22 pm »
Where are you seeing a schematic for the ADS 200?
Offline Shock
« Reply #1883 on: May 01, 2024, 12:43:29 pm »
I was talking 30V DC peak (loaded) measured from the handpiece on a scope. Would vary a little based on the mains supply but that would be adjusted for in the stations temp regulation.
Bdunham7 there isn't an official one, Mbless drew one after the station was released, prior to working on his own controller.
https://www.eevblog.com/forum/reviews/newest-pace-ads200-production-station-(a-jbc-killer-at-$239)/msg1742054/#msg1742054
« Last Edit: May 01, 2024, 12:46:08 pm by Shock »
The following users thanked this post: tooki, bdunham7
Offline tooki
« Reply #1884 on: May 01, 2024, 02:05:19 pm »
clickable URL (The stupid forum software hates dollar signs in URLs if not manually wrapped in URL tags.)
Offline thm_w
  • Non-expert
« Reply #1885 on: May 01, 2024, 09:32:14 pm »
Yeah there is no capacitance on that VAA rail shown in the schematic, 30V peak then RMS would be less, 21.21V in this case not 24V as I had used.
21V RMS, then absolute maximum peak power is ~112W.
If there is capacitance, then RMS would be higher. You'd need to measure the scope waveform.
« Last Edit: May 01, 2024, 09:34:17 pm by thm_w »
The following users thanked this post: SteveyG
Offline tooki
« Reply #1886 on: May 02, 2024, 06:50:37 am »
I haven’t been able to find any actual specs on heater voltage or resistance, nor any measurements, but it does not follow from a lower voltage that the power would be lower, since they will have designed the heaters to match the voltage they chose.
Yes, but there is no capacitance, and since the design relies on zero-crossing detection, there cannot be any capacitance on VAA.
Offline thm_w
  • Non-expert
« Reply #1887 on: May 02, 2024, 09:43:24 pm »
4 to 4.2 ohms as mentioned above. I measured 4.24 ohms. Real world slightly more due to wire, contact, and other resistances.
Heater resistance should have been designed lower, 3.5 ohms or so. Or transformer voltage higher, etc.
Offline bdunham7
« Reply #1888 on: May 02, 2024, 11:53:36 pm »
I'm measuring 4.9-5.0 ohms on mine at the connector, including an large chisel Ultra tip.  At the cartridge contacts 4.6-4.7 ohms.  I didn't note any power difference between the Ultra and standard tips.  If they can deliver 24VRMS to the connector, then you have 115-125W at the connector with about 7W getting lost in the wiring.  That means that they might not have had to alter either the transformer or the tips to make the improvements.  It will be interesting to see what changes they have made just as soon as someone tears one down.
« Last Edit: May 03, 2024, 01:03:23 am by bdunham7 »
Offline pope
« Reply #1889 on: May 03, 2024, 12:14:05 pm »
It would be nice if PACE was showing some transparency and let the people know. Sales speech doesn't help much.
Offline Shock
« Reply #1890 on: May 04, 2024, 05:33:32 am »
Manufacturers don't tend to publish detailed technical changes between models, or even board revisions. Back when schematics were supplied they rarely did then either, you had to figure it out yourself.
Offline pope
« Reply #1891 on: May 04, 2024, 02:18:53 pm »
Well fair enough but the problem is that a sales speech won't convince me to upgrade/buy the newer version.
Offline pac1085
« Reply #1892 on: June 15, 2024, 09:48:46 pm »
I've been wanting to buy another power supply so I can have one dedicated to the tweezers I bought separately.  Maybe I'll buy a plus (gotta make sure the vendor will actually send me a plus) and take a look inside.  The firmware on an ADS200 is stored on the Atmel 89C51RB2, trying to figure out how to read that with this Xgecu T48 I purchased recently.  They have a definition for the RD2 which is the 64K version but not the RB2 (16K)
I'm guessing it's locked though? I don't know much about this stuff.
Would be cool if its just a new firmware...
« Last Edit: June 15, 2024, 10:11:41 pm by pac1085 »
Offline pope
« Reply #1893 on: June 16, 2024, 08:01:23 am »
Thanks, please let us know if you end up buying the plus version.
Would be even cooler if PACE let current and potential users know what has changed.
Offline tooki
« Reply #1894 on: June 16, 2024, 08:41:39 am »
Has anyone actually asked? Pace seems like the kind of company that would tell us, given how open they’ve been in the past.
Offline Hydrawerk
« Reply #1895 on: June 20, 2024, 10:26:36 pm »
Probably both hardware and firmware was changed.
« Last Edit: June 20, 2024, 10:28:12 pm by Hydrawerk »
Offline w9gb
« Reply #1896 on: August 20, 2024, 04:13:05 pm »
Too late to see request, I have a Pace TJ-85 and Foot Pedal that I will be selling/trading in couple months.
Downsizing my shop, after 40+ years.
greg
Offline w9gb
« Reply #1897 on: August 20, 2024, 04:18:42 pm »
During COVID (early 2020), I had a Pace ADS200 power-up, but a blank screen.
This was an early ADS200 production model.
Talked to Aaron Cohen, and said to ship to North Carolina service (repair would be covered).
From what I gathered … change was made (component, firmeare?) to resolve issue.
Regarding the ADS200 Plus , sounds like component changes and
possibly transformer/power change (120 Watts).
greg
Offline tooki
« Reply #1898 on: August 20, 2024, 05:37:49 pm »
The original was already 120W, at least as far as the hardware is concerned. For some reason, the originals seem to never operate at 100% duty cycle. I am not aware of anyone having yet carried out a comparison with the plus version.
Offline thm_w
  • Non-expert
« Reply #1899 on: October 08, 2024, 09:03:30 pm »
Got rid of all my Pace gear but finally got around to grinding down a burned tip:
Very similar to the C210 design of JBC shown here: https://www.eevblog.com/forum/projects/axxsolder-jbc-soldering-controller/msg5124267/#msg5124267
I don't know how the outer wire was bonded to the tip (2), maybe spot welded or soldered, it came off easily when I was grinding.
