Hello Pace Owners,
My 1 year old ADS200 has been working great, but I've noticed an random intermittent fault. The problem has occured 3 times during the past 5 months.
The problem is that when the station is turned on, the LED display is all screwed up. It displays random segments and while it changes you can tell that the processor is trying to display the correct information the LED segments that are lit, are quite random. Then after the station has been on for a while, a few seconds to few minutes, the display seems to 'smarten' up and displays the correct information. Turning the station off and then on, while it is in crazy display mode, does not fix the problem, but turning the station off and then on after it has fixed itself leads to normal behavior. I'm concerned as yesterday's display failure took several minutes to return to normal.
I'm wondering if anyone else has seen or heard of this problem, and if anyone knows what causes the problem? Now that the unit is just over the 1 year warranty, I'm wondering how much of a pain its going to be to track down this problem and then solve it?
