Author Topic: Pace ADS200 soldering station  (Read 443320 times)
0 Members and 15 Guests are viewing this topic.
Offline particleman
Re: Newest Pace ADS200 station (tempting durability, and just over $200)
« Reply #975 on: March 03, 2019, 12:05:52 am »
I'm in Canada and have not purchased with them before. But search works wonders and I noticed "Gift Certificates or Coupon Code" appears at check out. Good reading: https://www.eevblog.com/forum/testgear/eevblog-members-discount-at-tequipment/
Thanks I found that thread. I needed to read 58 pages to find the code.  Station and 3 tips for $265.00 shipped.
« Last Edit: March 03, 2019, 12:10:41 am by particleman »
The following users thanked this post: Shock
Offline Shock
« Reply #976 on: March 03, 2019, 01:37:28 am »
I just noticed Pace has expanded the ADS200 standard tip range to now include a few more of the specialty and rework style tips, nice to see. Here are a few of them to give you an idea.
So the current count on their website is 45 Standard and 17 Ultra performance.
« Last Edit: March 03, 2019, 02:02:37 am by Shock »
The following users thanked this post: Cliff Matthews, tooki
Offline grantb5
« Reply #977 on: March 03, 2019, 02:19:06 am »
I believe there is still EEVblog member pricing here:
https://www.tequipment.net/Pace/ADS200-8007-0579/Soldering-Stations/
This is where I got mine toward the end of last year. I can give you the code. You input it quite late in the checkout process if memory serves.
« Last Edit: March 03, 2019, 02:20:51 am by grantb5 »
Offline grantb5
« Reply #978 on: March 03, 2019, 02:23:03 am »
How do you use the square one? Once heated I would imagine you only have a second or two to get the part off. Shake the board? Desolder it upside down? Obviously I've never done that before. I assume this is for a QFP or PLCC or similar...
Offline Cliff MatthewsTopic starter
    • General Repair and Support
« Reply #979 on: March 03, 2019, 02:27:20 am »
With the hot tweezer delay, I'd guessed manpower was assigned to other products.. so pleasant surprise to see new tips :-+
(but at $91 Canuckistan bucks, the 25mm shovel will have to wait a while..). Yes, I'd appreciate a PM on that code Grant.
Offline Shock
« Reply #980 on: March 03, 2019, 09:00:37 am »
Pace offers a few handpieces that do this kind of thing the TP-65, TP-100, SX-100, MT-100, TD100, TD100a etc. There is no suction on the ADS200 TD200 handpiece but you can use pickup tools for removal on tips with openings on the corners. These two videos cover the same principles of desoldering and removal even though it's for the TP-65 and hot air.
Offline Shock
« Reply #981 on: March 03, 2019, 09:20:29 am »
They probably got a few things going on in the background if they are expanding the Accudrive series i.e. 2 or 3 channel stations, it sort of makes the new mini tweezers essential. More aluminum!
« Last Edit: March 03, 2019, 09:22:42 am by Shock »
Offline labjr
« Reply #982 on: March 03, 2019, 02:48:35 pm »
I wonder if Pace will make a custom branding iron tip for my ranch?  :-DD
Offline tooki
« Reply #983 on: March 03, 2019, 03:36:51 pm »
They probably would if you paid them enough! :p
Offline rigrunner
« Reply #984 on: March 04, 2019, 04:36:10 pm »
Pace worldwide have responded today.
They want the tool stand back to see what failed and they're sending a replacement out along with updated firmware.
No quibble, just where do we send the replacement.
Excellent support  :-+
Edit:
Forgot to add that they informed me that my unit was built in July 2018 and stocked by Farnell in October 2018.
« Last Edit: March 04, 2019, 04:38:57 pm by rigrunner »
Internet of Things: A solution desperately trying to find its problem
The following users thanked this post: allan_wind
Offline particleman
« Reply #985 on: March 08, 2019, 07:06:50 pm »
The ADS200 showed up yesterday with 3 tips. So far so good. Seems like a nicely built station. I will be able to use my Edsyn 951 now exclusively for through hole work and the pace will be mainly for SMD soldering. I needed (wanted) something with faster, easier hot tip changes. It gets old burning yourself changing tips.  Im glad to see Pace  expanding the rework tip lineup for the ADS200, thats a good sign for owners.
Online joeqsmith
« Reply #986 on: March 23, 2019, 04:36:46 pm »
Ended up staying with the older technology.
Home made holder for the MT-100 MiniTweez that bolts to the side of my older P90 holder.   Takes up no room and is VERY easy to take the tweezers in and out.   Having used these tweezers with Pace's holder for many years, another advantage is there is no stress placed on the rubber handles.
I may add some holes to the top to hold a few of the tips.  Desk stays clean when I am working and having the tip exposed has not been a concern.
Would have liked to bought the new setup but I really was not sure when they would become available.   I have a lot of experience with these and have been very happy with them except for the damage I have shown to the handles.
I did get the iron to go with it but I've been very happy with the old P90 workhorse.
Offline Shock
« Reply #987 on: March 23, 2019, 07:19:47 pm »
On mine, I might slightly widen the lower part of the tweezer holder that supports the grips. Put some heatshrink on that and the top part that the black plastic rests on, those look like the contact points.
Offline LightlyDoped
« Reply #988 on: March 26, 2019, 02:51:26 pm »
There's a mistake in the manual for the ADS200 regarding replacement sponges for the tool stand. The correct part number is 4021-0013-P3.
I ordered some sponges from TEquipment using the part number in the manual, and the sponges looked nothing like what came with the stand. I didn't bother sending them back because the cost was minimal. I emailed customer service at Pace about the discrepancy, and got a quick thank you for pointing out the incorrect part number. They sent me some sponges at no cost. Really great service.
« Reply #989 on: March 26, 2019, 03:07:04 pm »
That's only part of what makes Pace a real JBC Killer :box: No, I won't change back the title, fan-boy's are a pain in the sponge..
Offline labjr
« Reply #990 on: March 26, 2019, 03:29:43 pm »
Then at least take off the parenthesis.
Offline grantb5
« Reply #991 on: March 26, 2019, 03:47:50 pm »
I'm guessing this photo is wrong then?
https://www.tequipment.net/Pace/4021-0013-P3/Soldering-Accessories/
I think you're right, mine appear smaller and have the 'H-cut' in them..
Offline grantb5
« Reply #993 on: March 26, 2019, 04:07:48 pm »
A bit off subject. TEquipment doesn't carry the Kester line of solder products. But they have this. Has anyone tried this bargain solder? Has good reviews.
https://www.tequipment.net/Amerway/AM63.37.SPOOL.1LB/Solder-Wire/?b=y&v=124481
Did you try it?  I don't see where it says what kind of rosin flux it is.
« Last Edit: March 26, 2019, 04:15:25 pm by grantb5 »
« Reply #994 on: March 26, 2019, 04:17:56 pm »
That photo is wrong. It's the same photo that's shown with the incorrect part number from the manual. (Some other online retailers also show the wrong photo.) I can't vouch for whether TEquipment will send you the correct sponges even with the correct part number, so you might want to contact them before ordering. If you order directly from Pace, you'll get the correct sponges:
https://www.paceworldwide.com/products/spare-parts/replacement-sponges-for-new-tip-and-tool
Hmm, Amerway solder in PA and Tequipment could be closer than one might think.. I've posted on Amerway before I think.
« Reply #996 on: March 26, 2019, 04:36:44 pm »
Thank you for no longer triggering me with the original provocative title. By the way, the sponges are great for detailing your car.
Offline grantb5
« Reply #997 on: March 26, 2019, 04:43:21 pm »
"It is standard rosin core.  It is neither no clean nor water soluble"
Offline labjr
I plan to order a roll of that solder at some point. For $10, I'l give it a shot. Reviews say it has good wetting properties.
Offline Jacampb2
Hey folks,
I bought a Pace ADS200 in February of this year. I use it for hobbiest level repair work. Last week, my tip I use most went open. I have used a hakko 935 for almost 20 years and have never had a heating cartridge go open. I've replaced tips due to oxidation, but never have I had a cartridge fail.
I wrote to pace worldwide to inquire what the expected life on their cartridges is and whether there might be a fault with my unit, 2.5 months of use did not seem acceptable. They have not bothered to reply. I went ahead and ordered more tips, but yesterday I had it blow one of the other tips open. This one had barely any use, maybe 2-3 hours over the last two months.
I'm wondering what kind of life the rest of you are getting out of the cartridges? I really think there may be an issue with my unit. Fwiw, I never use a sponge, I know it's harder on plating, but I use the brass wool. The point is, these types are not seeing repeated thermal shock.
Thanks,
Jason
