Author Topic: Pace ADS200 soldering station  (Read 454163 times)
pac1085 and 1 Guest are viewing this topic.
Offline VK4GHZ
Re: Newest Pace ADS200 production station (a JBC killer at $239??)
« Reply #550 on: July 19, 2018, 12:48:12 am »
Why has Dave's video been taken down?
No more freebies from Pace if it wasn't?
Offline Dubbie
« Reply #551 on: July 19, 2018, 12:50:45 am »
I got 5 mins in before it was yanked.
Offline labjr
« Reply #552 on: July 19, 2018, 12:59:31 am »
I realize that soldering at such a low temperature isn't the norm. However, I'd think you wouldn't have to crank it up so much higher than the JBC?  It certainly has enough power to deliver. If the tip remains under load, why doesn't it continue to deliver power until it's up to temp?
Offline helius
« Reply #553 on: July 19, 2018, 02:02:20 am »
As heat transfers from the tip to the work, the tip cools, and the sensor then detects the cooling, and the MCU then sends more power to the heater.
But, if there is no solder bridge because the temperature of the work is below reflow, heat can't move out of the tip, so the sensor stays hot, and power doesn't increase. It's the same reason that you can't solder with a dry tip and need to touch the solder to the tip before feeding it onto a pad.
The tip geometry, composition, and plating determine the thermal resistance, RT in °C/W: the temperature difference required per watt of heat transfer. On a workpiece with a heavy ground, more heat transfer is needed to keep the solder molten, so the tip must be hotter.
One of Pace's comments indicates that their tips are higher RT compared to JBC, because they have heavier plating.
In other words, it's a false belief that you can keep a low tip temperature on any kind of work, just because you have the ability to supply high power. The RT means that the minimum usable tip temperature is always higher for heavier workpieces.
The following users thanked this post: Shock, Dyaxxis, PACE-Worldwide
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #554 on: July 19, 2018, 02:13:15 am »
From the video, it seems to me the PACE control loop is taking too long to update power as an ƒ(temp), in the scope you can see the JBC feeding more power every few (mains) cycles, in the PACE it's more like only a couple times/second or so instead. That may be too slow if the rate at which the ground plane cools the tip is faster than that.
« Last Edit: July 19, 2018, 02:15:08 am by GeorgeOfTheJungle »
Online EEVblog
« Reply #555 on: July 19, 2018, 02:45:24 am »
Because the thicker iron plating has higher thermal resistance and therefore the temperature of the solder on the ground plane is much lower, so the tip is effectively "dropping" that temperature. Just like the old style contact tips have a higher thermal resistance again. It's the basic resistor-thermal analogy. I prefer the lowest thermal resistance in the tip I can get, so that the displayed temperature is at least closer to the actual joint temperature. Tip life be damned. But as always, YMMV.
« Last Edit: July 19, 2018, 03:10:10 am by EEVblog »
The following users thanked this post: Dyaxxis, PACE-Worldwide
Online EEVblog
« Reply #556 on: July 19, 2018, 02:49:02 am »
No, I don't give a toss about freebies.
Several commenters and Pace were right, it wasn't clear why I was soldering that ground plane at 270C. I didn't want people thinking you should be doing that, it's confusing. As was my statement about soldering "at the lowest temperature possible", I did not articulate it well enough, well, at all really.
I also added some stuff about the iron plating differences, showed the Hakko 888 and added the JBC temp measurement.
I have reshot that bit and will upload a new version.
I think Pace's claim about "unsurpassed thermal performance" is bullshit, and I say so in the video. They can argue all they want about tip life plating tradeoff and higher temps all they like, when you make a claim like that it's going to be tested. And there is only one way to test that, at the lowest temperature that shows the differences. I think it's quite disingenuous of Pace to claim that it's "unfair" and that only a higher temp should be used to make it fair. If that's the case, the Hakko 888 performs the same. The Pace doesn't match the thermal performance of the JBC, it can't due to the higher resistance tips, they know that, and they admit that with the iron plating explanation. Yet their marketing says opposite.
« Last Edit: July 19, 2018, 03:11:46 am by EEVblog »
The following users thanked this post: CustomEngineerer, tooki, VK4GHZ, knapik, Dyaxxis, PACE-Worldwide
Online EEVblog
« Reply #557 on: July 19, 2018, 03:13:15 am »
If the solder isn't melting at the set temperature, then isn't the tip temperature lower when it's under load?
Yes. No matter how good your soldering iron and tip, the actual temperature of the joint always drops due the unavoidable thermal resistance.
Cue the Metcal induction fanboys...
Offline helius
« Reply #558 on: July 19, 2018, 03:49:42 am »
"Unsurpassed thermal performance" can be interpreted in multiple ways. It isn't just another way of saying "low thermal resistance".
Just ad lib, you could be talking about setpoint accuracy, setpoint variance, ready time from standby, recovery time, overshoot, or energy efficiency: these are all thermal performance parameters. Different users will weigh these factors differently, according to their preferences and needs.
For both thermal conductivity and total heat delivery, it's very hard to match a Weller D550 with a solid 12ga. copper wire! But such a tool has limited application to modern electronics.
The following users thanked this post: tooki, Dyaxxis, PACE-Worldwide
Offline labjr
« Reply #559 on: July 19, 2018, 04:00:08 am »
Now I'm more curious about an ADS200 vs FX-951 comparison.
The following users thanked this post: nowlan, tooki
Offline Bud
« Reply #560 on: July 19, 2018, 04:21:00 am »
Dave can you add a compare of tip oxidation JBC vs Pace. It is bad tip oxidation on JBC which drives me mad. If Pace is better i will not care about rest of the story. Great ergonomics handpiece and low oxidating tips will do it.
Online EEVblog
« Reply #561 on: July 19, 2018, 06:04:04 am »
Problem is that's a really long term experiment. I don't know of way to accelerate it that would realistic?
Online EEVblog
« Reply #562 on: July 19, 2018, 06:06:37 am »
Sure, but few people are going to argue that temperature drop on the the tip (a.k.a tip thermal resistance) isn't one of the main criteria for determining thermal performance.
Indeed, soldering irons are split into two design camps (three if you include induction based tips like Metcal) entirely based on this concept alone.
Offline Shock
« Reply #563 on: July 19, 2018, 06:32:15 am »
Heard a knock on the door, look what has arrived.
Offline presjar
« Reply #564 on: July 19, 2018, 10:23:22 am »
Hi PACE-Worldwide
Nice work letting the Australian distributors get away with a price of $543AUD ex Tax. Only a mark up of 67%!   :palm:
239USD = 325AUD x 1.67 = $543AUD
Really looking out for the users on this forum.  :-DD
Online EEVblog
« Reply #565 on: July 19, 2018, 10:36:49 am »
So they do stack!
Online EEVblog
« Reply #566 on: July 19, 2018, 10:37:41 am »
Not cheap to get one here in Oz, like $500 or something.
Online EEVblog
« Reply #567 on: July 19, 2018, 10:39:16 am »
Hi PACE-Worldwide
Hakko have basically the same mark-up here. i.e. the FX-951 is $542 AUD ex GST
Offline Shock
« Reply #568 on: July 19, 2018, 10:45:28 am »
Dave your power meter froze it seems while measuring the JBC.
Did you notice any slight temp overshoot while measuring the JBCs recovery on the thermometer?
Offline PACE-Worldwide
    • PACE Worldwide Website
« Reply #569 on: July 19, 2018, 10:53:16 am »
Offline TheAmmoniacal
  • Country: no
Online EEVblog
« Reply #572 on: July 19, 2018, 11:17:38 am »
Hi Dave,
As alank2 mentioned a few pages back, I hope you match the true temperatures of the irons being compared, as opposed to assuming the set temperatures are correct. Despite having great temperature accuracy, PACE cartridge style tips (as well as JBC, Weller, Hakko, et al) can run hot or cold, depending on the the shape of the tip, it's mass and the positioning of the sensor in the tip. See the attached photo for an example. Note that the PACE tip is reading an accurate temp of 520F, while the JBC Tip is set on 520F yet displaying 557F on the contact pyrometer! Let's compare apples to apples.
Aaron
« Last Edit: July 19, 2018, 11:36:55 am by PACE-Worldwide »
Online EEVblog
« Reply #573 on: July 19, 2018, 11:55:46 am »
Watch the new video, I do that on all three irons.
I did. Watch the video instead of using someones else's iron!
The JBC was set to 280C and displayed 285C (tops, kinda creeped up to that).
That 5C difference doesn't explain the 30-35 degC difference in the performance on that ground plane.
Quit the sour grapes and just admit it, your choice of thicker ion plating increases the tip thermal resistance and it cannot match the JBC in performance as result. There is nothing wrong with that, just say it and market it that way. i.e. "we deliberately trade off tip life for thermal resistance".
And in case you missed it in the video, I also mention this stability aspect of your product and say it's one of the good points.
« Last Edit: July 19, 2018, 11:57:17 am by EEVblog »
« Reply #574 on: July 19, 2018, 11:59:52 am »
"We deliberately trade off tip life for thermal resistance": ... there I said it! But I won't market that, heh heh heh.
Watching the new version right now!
