Author Topic: USB powered irons (Pinecil and similar)  (Read 29651 times)
Offline rteodor
Re: USB powered irons (Pinecil and similar)
« Reply #25 on: February 14, 2024, 07:45:18 pm »
thanks @watchmaker and @rteodor.
@rteodor, are you using the same PSU @watchmaker mentioned?
Its PinePower 120W desktop (EU). I don't know if there are differences from (US).
Offline tony359Topic starter
« Reply #26 on: February 14, 2024, 07:56:25 pm »
Well I think it's safe to assume it grounds the USB.
In any case, the Pinecil provides ground points. The Kaiweets does not - I'll see if by grounding the USB shield the voltage at the tip goes away otherwise it's just something to consider when purchasing.
